replacing fuel bowl heater - Diesel Forum - TheDieselStop.com
post #1 of 12 (permalink) Old 02-24-2012, 04:35 PM Thread Starter
I need to replace the fuel bowl heater in the early 99 psd. have the new one in hand.
now wondering about replacement procedures and if there are O Rings or what to seal up the wire entry point.
If you can stear me to a how to I would appreciate it.
Dave
Early 99 F 250, Walker Big Truck Muffler, CCV Mod, Otherwise bone stock at present.
HenryE is offline
post #2 of 12 (permalink) Old 02-24-2012, 05:19 PM
RT
RT's Avatar
If all you are doing is pulling the heater, you just pull the wires on the inside with needle nose pliers. You don't have to pull the WIF sensor / heater connector off the bowl. The heater has two #20 TORX screws holding it down. Pull those out, pull out the heater, and replace.
Keep one finger on that black "tower" in the center - it can pop up once the heater is loose. If it does come apart, you can just put it back together when you go to reinstall. There are some pictures in this link: http://www.dieselorings.com/docs/FuelBowlRebuild.pdf
RT is online now
post #3 of 12 (permalink) Old 02-25-2012, 10:46 AM Thread Starter
thanks RT, a pic is worth a thousand words.
HenryE is offline
post #4 of 12 (permalink) Old 02-29-2012, 03:48 PM
I was having a problem with fuse #22 on my 97 PSD and this thread helped me narrow it down to the fuel bowl heater. I drained the fuel in the bowl and unplugged the heater, changed out the filter (which was due) and the truck started without blowing the fuse. Now on to the issue. My heater does not look like the one in the link. It has a hex attachment at the bottom of the black tower and looks like a slotted plate that goes round the circumference of the bottom of the bowl. The little wire hasps were shorted out so I knew I had my culprit right when I drained the fuel. How do I get to that hex nut with the tower in the way?...it's deeper than my deepest socket from the looks of it. Thanks, Ben (Sullied Diesel)
Sullied Diesel is offline
post #5 of 12 (permalink) Old 02-29-2012, 04:20 PM
RT
RT's Avatar
Sullied - you will likely get more help if you start a new post in the antique truck section - Power Strokes 1994-1997 General - Diesel Forum - TheDieselStop.com
RT is online now
post #6 of 12 (permalink) Old 02-29-2012, 04:27 PM
klhansen's Avatar
My Photos: (180)
Fuel bowl is different on the OBS trucks. There was something I recall about the center post being left handed threads to remove. You can probably unscrew the center post with some water pump pliers. Check with the guys down in the 94-97 Powerstroke General Forum.
), AIS,
regulated return,
klhansen is offline
post #7 of 12 (permalink) Old 02-29-2012, 05:30 PM
chuckster57's Avatar
If a '94 PSD is an antique, what's that make the IDI?
Sullied: all the information that I have access to shows the same heater that RT linked to. Kevin mentioned that you may have to remove the center piece..
Train Horns:
PM please not visitor message
chuckster57 is offline
post #8 of 12 (permalink) Old 03-01-2012, 06:00 AM
Thanks all, I saw on one of the parts sites that the thread was left hand...saved me a bit of grouching. I'll assume the newer heater superseded the plate type and will fit my bowl because several sites list it for the older trucks as well. Thanks again for all your help, this one thread saved me from having to flatbed it to the diesel guru's for a 15 minute job.
post #9 of 12 (permalink) Old 01-23-2014, 09:37 AM
lubbockguy1979's Avatar
Send a message via Yahoo to lubbockguy1979
does the fuel filter housing need to be removed to replace the fuel bowl heater?
2006 f250 4x4
crewcab short bed
lariat 6.0psd
auto, electric tcase
soon to have isspro
fire/air/trans/fuel
stock suspension and
pretty much everything
else
lubbockguy1979 is offline
post #10 of 12 (permalink) Old 01-23-2014, 09:46 AM
RT
RT's Avatar
Not at all. Two bolts and a push on wire. The directions are on this page - http://www.dieselorings.com/1999-200...r-element.html
They are for the full fuel bowl rebuild, but you can just do the part that pertains to the truck you are working on. This does NOT apply to the truck in your signature. This is for the 99-03 7.3 engine. If you are talking about your 06, you'll need to post that question to the 6.doh experts.
RT is online now
post #11 of 12 (permalink) Old 01-23-2014, 09:58 AM
Bill1013's Avatar
Your post is in the 99 and up to 2003 7.3 PSD. If your 6.0 fuel bowl is the same as the 99 up, then it's a simple matter to change the heater. Pull the filter out, see two screws at the bottom, disconnect the two wires with needle nose, I don't think you have to pull the center tower out, if you do, it may be left hand threads. Did mine (99) two yrs. ago so don't remember. IIRC the two screws were #20 torx.
99.5 F350 XLT Lariat 4X4 4R100 4.10 DW CC LB Centurion conversion, 183K miles Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 2WD 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U, 79K on the engine. 129K body.
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast. One Flash and it's gone forever.
Bill1013 is offline
post #12 of 12 (permalink) Old 01-24-2014, 01:32 AM
Actually I was working on a shop truck. Its a early 99. The 6.0 dosent have a fuel bowl heater btw. The element came out easily. Two t20 torx bolts. I got 4 of the glow plugs done today and should rap up the other half tomorrow. Hopefully she will be good as new when im done
2006 f250 4x4
crewcab short bed
lariat 6.0psd
soon to have isspro
fire/air/trans/fuel
else
