Replacing pulleys on Serpentine Belt Tensioner - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 02-11-2010, 03:12 PM Thread Starter
Has anyone replaced the pulleys seperately on the tensioner in lieu of replacing the whole unit?
I have replaced the single fixed pulley and have seen the assembly sold for about $65 but would rather replace just the pulleys and not the whole assembly.
2OOO F-250 4WD Crew Cab, 267,000K miles,
Stock. Replaced #1 Injector/harness, Starter Relay,CPS(twice), GPR, VSS, S-Belt, Alternator, H2O Pump. AIS Severe Duty Filter, Bilsteins, Heater shutoff valve, Rotella Syn, Nitto TG's 305/55 on Eagle 20x10's, Mobil 1 ATF,Walker BTM, Mesa, Arizona
PRDATR is offline
post #2 of 8 (permalink) Old 02-11-2010, 03:22 PM
tbpower's Avatar
Unless you have replace the whole unit before I would get the entire assembly. Cheaper than a tow bill. Mine started to go out around 175 k and lucky I caught it before I got stranded.
2000 7.3 powerstroke. PHP 6 position chip (stock,high idle,60tow,80dd,100hp,no start) . 6637 riffraff filter kit . AIH delete. Oil crossover. 6.0 tranny cooler. In tank mods. Wicked Wheel. EBPV delete. Walker 21470 muffler. Riffraff FRX
tbpower is offline
post #3 of 8 (permalink) Old 02-11-2010, 06:15 PM
Flywheel's Avatar
I recall that you can change the bearings in them - but can't remember the art number of the bearings - it may be printed on there.
I just pulled my pully's off from the ranch truck not too long ago - they were pretty dry, so I just lubed them. You can pick the plastic grease keeper off and access the bearings. I just used bearing lube on the end of a zip tie to get it in there.
Trail Boss Replacement Bumpers, Tool Box, Headache Rack, Full Length Running Boards, BFG AT/KO 285/75x16E, 2003 Cup Holder, Marinco Heater Plug, Weather Tech Rain Vents / Hood Guard, B&W GN Hitch, X-Springs, Rear 4" F350 Blocks, Hellwig front and rear sway bars, Airlift / Wireless, Duraflaps
Isspro A-Pillar Gauges, Isspro TTM, Ford AIS, Magnaflow 3.5" DP - 4" Exhaust, Garrett GTP38R Turbo, Turbo-Master, High Flow Outlet, Non EBV Pedestal, IH Up-Pipes, DS 203 degree Stat, OA, BTS Tranny, 6.0L Tranny cooler, DP-Tuner F6, FRX, Cass Stage 1s, T500 HPOP, DieselSite HPX
99 F-250 CC SB 4x4 7.3 White
Ranch Truck, Ranch Hand brush Guard, Original Cup Thrower, DP-TUner F6, 4" Turbo Back Magnaflow, AIS Intake, 6.0 Tranny Cooler, Ford 4R100HD, CM Flatbed
Autoenginuity
Flywheel is offline
post #4 of 8 (permalink) Old 02-11-2010, 06:26 PM
Its a 6203 bearing, a very common size. You can save some money by pressing in new bearings.
early 99F350 Crewcab coolant filter, guages, 4 inch exaust, Ford HD trans, intake, 340,00 miles 96 F250 Supercab, coolant filter, jasper E4OD, carquest trans cooler,banks trans-command, 3.55, tymar intake,4 inch exaust, no cat, Donaldson muff,Westach dual guages,factory AIC, HX mod,one of Bill's 3 position chips ,JOE SERVO IDM, A/C mod, Baldwin bypass filter,Stancor GPR, 340,000 miles, bought new. I pull a 8000 lb. gooseneck daily. early 99 F-350,Auto,crew-cab, 380,000 miles..
davmo is offline
post #5 of 8 (permalink) Old 02-11-2010, 07:29 PM Thread Starter
Auto Zone wants 27.00 for the pulley so I ordered one and it will be here Saturday.
I don't have a press but will look into replacing the bearing after I get the pulley off just to do it and keep it as a spare.
Interesting thing is they showed two pulley's for the Idler Pulley. A smooth and a grooved! My truck has the smooth so I grabbed the grooved one they had in stock and it was 1/2 bigger then the grooved one on the tensioner.
Probably would have worked but I ordered the other one which I hope has a diameter of 3 1/4".
PRDATR is offline
post #6 of 8 (permalink) Old 02-11-2010, 07:31 PM
should this be PM? (I have 160K+) I have a 3 ton and 12 ton press and many many bearings incl 6203's. How many and what types do I need to replace all???
2001 X, 4x4, White, Limited, PSD,. Oil Guard, Stull 6099 Grille, AFE Intake, X Monitor, Sonnax/Tricumulator, Mobil 1 ATF w/Racor tranny filter, PHP Custom Burn Chip, Walker BTM, W Code Frt Springs, Procomp Add-a-Leaf Rear, Rancho 9000XL's w/5406 SS. Pics @
TXANGLER is offline
post #7 of 8 (permalink) Old 02-11-2010, 07:34 PM
Originally Posted by TXANGLER View Post
should this be PM?
Yes it should.
444-4D is offline
post #8 of 8 (permalink) Old 02-11-2010, 08:01 PM
When and are they all 6203's and how many?? I am going to do mine and Pop's 00 at the same time.
TXANGLER is offline
