right front axle seal leaking - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 04-16-2005, 12:15 PM Thread Starter
The passenger side front axle seal is leaking. Can someone point me to some directions on how to replace myself? or is it to involved for a backyard mechanic? i have it down to the knuckel..is there a c clip behind the diferential cover? HELP!
Y2K F350 Lariat, Born on 01-00, CC, 4x4, DRW, LB, White, 6spd Short Shift, Hutched, Pre-Pump, HX, Pooned, DI Fuel Reg, GPT38R BB, EBPV Delete, Swamps 200cc Single Shot Hybrids, 4" Exaust Straight Piped, Bilstien shocks, Jordan Brake Controller, B&W Flip Hitch, Timbren Load Springs on rear, Zoodad, Donaldson Filter, TS Performance stock-high-idle-60-80-100-140, Pillar IssPro Gauges,
Riley coolant filter, Evans Coolant, 203T-Stat, SP Performance EBP sensor, CCV Mod to atmosphere, MileMarker hubs, South Bend Con OFE, Ranchhand front bumper, Hillsboro aluminum flatbed ...!!!
termite is offline
post #2 of 10 (permalink) Old 04-16-2005, 01:26 PM
Banned
Re: right front axle seal leaking
I understand that this is the axle seal at the differential that we are discussing?
There is no C-clip in the differential though the large seals at the knuckle can fit very tight (I recommend changing these and servicing the spindle bearings since it will all be apart, anyway). Both front axle shafts will have to be removed as will the diff cover and the front carrier ass'y. Do NOT mix up the bearting cups NOR the side bearing shims.... The caps in the diff fit only one way (though they will go in several diffeerent wrong ways) and it can be difficult to install the side bearing shims without breaking them.
Once you have it all apart, replace both axle seals at the same time to avoid a repeat performance. Make sure the housing vent is free of obstructions. Installing the seals without the special tool can be a real PITA tnough many have devised work-arounds.... speaking of work-arounds, there is a plastic guide in each axle tube to assist in installing the drive axles... if this guide is damaged or missing, the resulting frustrations can send you postal in short order.
HTH.
GrampyJim is offline
post #3 of 10 (permalink) Old 04-16-2005, 01:46 PM Thread Starter
no it is at the end of the axle towards the rotor.
termite is offline
post #4 of 10 (permalink) Old 04-16-2005, 02:34 PM
There are 2 seals there.
One is the actual hub seal and rides right next to the hub bearing and is about the size of a coffee can. The other is the end axle tube seal it is about the size of a Coke can. Which one are you talking about? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Dale_Lakin is offline
post #5 of 10 (permalink) Old 04-16-2005, 02:41 PM Thread Starter
The end axle tube seal.
termite is offline
post #6 of 10 (permalink) Old 04-16-2005, 11:18 PM
my wifes 2k just started leaking there too.....my 97 dosnt have outer axle seals....im gonna find out next week. there shouldnt be a clip in the carrier that axle should just pull out. the axle can be kinda difficult getting outta the inner axle seal though.
97 F250HD 4X4 210K MI
4 LINKED FRONT AND REAR ON AIR
00 F350 4X4 CC
RIP CHRIS. 03/09/05
barebackjake is offline
post #7 of 10 (permalink) Old 04-17-2005, 12:18 AM
I'd bet that your left hub is stuck in the locked position, and the right hub is unlocked. Don't touch the hub dial. Raise the left wheel and turn it while watching for rotation of the axle universal. This happened to me and for some reason it pumped oil out of the right axle tube after about 100 miles of highway driving. The axle tube end seals are only dust seals. The real seals are inside the diff.
7.3 Excursion, it's a diesel thing.
Chicago MOB member.
shamuex2000 is offline
post #8 of 10 (permalink) Old 04-17-2005, 04:04 AM
Banned
The seal on the end of the axle tube is there to seal dirt out of the tube only.... If you have oil leaking out of it, you are going to be disappointed when you get it apart.
The oil seals for the front axle driveshafts are mounted inboard, in the "pumpkin"... plan on spending some time.
post #9 of 10 (permalink) Old 04-18-2005, 11:33 PM
dang was afraid of that. rebuiding D60 for my 97 right now i know what i gotta do.....she had the hubs locked and was driving it all over everywhere so now that there unlocked ill see how much it leaks till i get time to do them and do them both.
00 F350 4X4 CC
RIP CHRIS. 03/09/05
post #10 of 10 (permalink) Old 04-19-2005, 08:07 PM Thread Starter
so this may be a stupid question ......but if i unlock my left hub......will the right stop leaking? if that is the problem???
termite is offline
