Rough running when cold - HELP with some codes????
Just bought a 2002 E-550 and I pulled the following codes- P0113, P0475, P0541, P1316. The engine has a miss when it is cold but seems to get better once it's warmed up. Also, fuel milage is REALLY bad probably 7-8 MPG. Any ideas what I should be looking at? Could this be as simple as a loose connector on the wire harness? Since this thing is no longer under warranty 116K miles I would like to try some things myself before taking it to the local Ford dealer.
Mike
2009 Dodge 5500 6.7L 4X4 Q/C
Gone but not forgotten...
-2007 Ram 3500 5.9L Q/C Dually
-2006 Ram 3500 5.9L Q/C
-2002 E-550 7.3L With 20' Box
-1999 F-350 7.3L 4X4 C/C Dually
-1997 F-250 7.3L 4X4 S/C
-1996 F-350 7.3L 4X4 R/C
-1995 F-350 7.3L 4X4 R/C
