Sensor abbreviations and locations - Diesel Forum - TheDieselStop.com
Old 09-21-2009, 12:45 PM   #1 (permalink)
Is there a diagram for, and an explanation of the various sensor abbreviations – engine, transmission, rear-end, turbo, etc?
I have had diesels in the past but non-turbo manual transmissions versions.
2000 E-350 7.3 turbo
Thanks in advance…
2001 E-350 7.3 Diesel
216,000 - New water pump.
minalba is offline
Old 09-21-2009, 05:23 PM   #2 (permalink)
klhansen's Avatar
My Photos: (168)
This is a good page for engine sensors.
Your Premiere Source for Ford Truck Parts and Accessories
For others, if you can get hold of a service manual, they're shown in there.
Hard or no-start? Check Here
klhansen is offline
Old 09-21-2009, 11:11 PM   #3 (permalink)
SmokeyWren's Avatar
My Photos: (44)
Code:
1999 PCED OBDII-Diesel 	SECTION 6: Reference Values
PCM Pin Descriptions
Pin # 	Name 		Comments
3 	MIAHM    	Manifold Intake Air Heater Monitor
5 	PBA 		Parking Brake Applied Switch;
6  	SS1 		Shift Solenoid #1
8 	GPMH 	        Glow Plug Monitor High Side;
9 	GPMR 		Glow Plug Monitor Right Bank;
10 	IVS 		Idle Validation Switch;
11  	SS2		Shift Solenoid #2
12  	TCIL		Trans Control Indicator Light;
13 	FEPS 		Flash EPROM Power Supply
14  	4X4L 		4x4 Low Switch;
17  	TR1 		Trans gear selected
19  	TAC 		Tachometer Signal Reflected CMP signal
20  	CCS 		Coast Clutch Solenoid;
21 	CMP 		Camshaft Position Sensor;
24 	APGND 		Accelerator Pedal Sensor Ground
28 	WIFIL  		Water In Fuel Indicator Lamp
29 	CPP (Manual)    Clutch Pedal Position Switch
        TCS (Automatic) Transmission Control Switch
30 	EBP 		Exhaust Back Pressure Sensor
31 	BPA 		Brake Pedal Applied Switch;
34 	GPML 		Glow Plug Monitor Left Bank;
35 	ALTI 		Alternator #1 (Top) Monitor
36 	WIF  		Water In Fuel
37  	TFT 		Transmission Fluid Temperature;
38 	EOT 		Engine Oil Temperature;
39 	IAT 		Intake Air Temperature;
40 	FPM 		Fuel Pump Monitor
41  	ACC 		Air Conditioning Clutch;
42 	EPR 		Exhaust Back Pressure Regulator;
47 	WGC 		Waste Gate Control
49  	TR2 	        Trans gear selected
50  	TR4 		Trans gear selected
54  	TCC 		Torque Converter Clutch Solenoid;
55 	KAPWR 		Keep Alive Power;
58 	VSS (+)         Vehicle Speed Sensor
59 	OSS  		Output Shaft Speed Sensor
60 	ALT2 		Alternator #2 (Bottom) Control
61 	SCCS 		Cruise Control Command Switch;
62 	MAT  		Manifold Air Temperature
66 	PTO  		Power Take Off Enable
67 	BATTL  		Dual Alternator Battery Lamp Indicator
70 	GPL 		Glow Plug Lamp,
71 	VPWR 		Ignition source power
79 	MAP 		Manifold Absolute Pressure
80 	IDM    EN 	IDM Relay;
81  	EPC 		Electronic Pressure Control Solenoid
83 	IPR 		Injection Pressure Regulator;
84 	TSS  		Transmission Speed Sensor
87 	ICP 		Injection Control Pressure Sensor
89 	AP 		Accelerator Pedal Sensor
92 	BOO 		Brake On/Off Switch;
94 	FP  		Fuel Pump Control
95 	FDCS 		Fuel Delivery Control Signal;
96 	CI 		Cylinder Identification
98 	MIAH  		Manifold Intake Air Heater
100 	FLI  		Fuel Level Indicator
101 	GPC 		Glow Plug Control,
SmokeyWren is offline
Old 09-22-2009, 07:23 AM   #4 (permalink)
Great information, thanks to both of you!
Minalba
minalba is offline
