Service Engine Soon Light - Diesel Forum - TheDieselStop.com
Old 11-03-2009, 02:34 PM   #1 (permalink)
Hey guys. This is probably a dump question, but my service engine soon light came on to day. The truck is running fine, except for the intermittent fuel leak at the fuel filter. Does that light represent a code being shot?
GWJ1 is offline
Old 11-03-2009, 02:45 PM   #2 (permalink)
Flywheel's Avatar
My Photos: (6)
Yes - a code is in your computer and will be stored for a while even if the light goes off.
99.5 F-250 CC LB 4x4 7.3 Red New Pics 1/5/10
Trail Boss Replacement Bumpers, Tool Box, Headache Rack, Full Length Running Boards, Bilstien Shocks, BFG AT/KO 285/75x16E, 2003 Cup Holder, Marinco Heater Plug, Weather Tech Rain Vents / Hood Guard, B&W GN Hitch, X-Springs, Rear 4" F350 Blocks, Hellwig front and rear sway bars, Timbrens, Duraflaps
Isspro A-Pillar Gauges, Isspro TTM, Ford AIS, Magnaflow 3.5" DP - 4" Exhaust, Garrett GTP38R Turbo, Turbo-Master, High Flow Outlet, Non EBV Pedestal, IH Up-Pipes, DS 203 degree Stat, DS Boost Relief, BTS Tranny, 6.0L Tranny cooler, DP-Tuner F5, DieselSite HPX
99 F-250 CC SB 4x4 7.3 White
Ranch Truck, Ranch Hand Bumpers, Original Cup Thrower, B&W GN Hitch
Autoenginuity
Flywheel is offline
Old 11-03-2009, 03:26 PM   #3 (permalink)
PowerstrokeConverters's Avatar
My Photos: (23)
Send a message via MSN to PowerstrokeConverters Send a message via Skype™ to PowerstrokeConverters
I get codes all the time but I have done some mods that throw codes so...
The light does not stay on, even when I overboost the light will go off after a couple of seconds.
Get a programmer that reads the codes, Superchips come with a booklet with all the codes and their meaning.
2000 F-350 7.3 PS ,4R100 Lariat Dually
http://i829.photobucket.com/albums/z...DSC02732-1.jpg
4x2 LB 3.73 gears, 115k miles(better than new)
6" Fabtech lift w/ duall steering stabilizers
22.5 polished Freightliner wheels
Triple Clutch Triple Bearings Billet Low stall Converter.
V10 Tranny cooler + Trucool max cooler
Wicked Wheel-loud little sucker!
DieselStop Boost fooler
Full Turbo back 4'' exhaust,
Triple Autometer Phantom gauges on pillar,
Now using Superchips 80hp Performance tune.
Wastegate disconnected
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
4'' Ported Housing non-ATS
IC pipe ceramic coated w/ foil delete
Inlet heater deleted.
3 tv's + Backup Cam,DVD,Nav.,Satelite Music.IPod
Jason smooth topper.
Big air compressor/tank
2 air horns w/ big valves
Quick connect Air hose for any air tool/tires
All work done at DieselTriple.Com-Miami,FL
Here but not installed:ATS 1.00 a/r, non-ebv pedestal and outlet,turbo master actuator,203 thermo.,billet thermo. inlet.
Pictures:http://photobucket.com/2000_F350
PowerstrokeConverters is offline
