Signs of failing HPOP - Diesel Forum - TheDieselStop.com
Old 03-08-2005, 12:22 PM   #1 (permalink)
What are the signs that an HPOP might be on it's last legs.?
2002 F350 CC, SB XLT 6spd, Luk clutch, 285/75R16 Goodyear Wrangler Silent Armor
4" Magnaflow Turbo Back Exhaust
DP Tuner: 80econo, 60econo, 40tow high Idle
gjs1 is offline
Old 03-08-2005, 02:19 PM   #2 (permalink)
Re: Signs of failing HPOP
My HPOP was droping pressure on the higher chip settings. A pressure gauge is a sure way to check.
Otherwise, SOTP will tell you the torque drops off in the upper RPMs. Also, the smoke diminishes in the upper RPMs. With a new HPOP mine now smokes WOT until I let off. Before I never saw smoke but only during initial acceleration.
1999 F250 XLT 4x4, SC SB: BTS Auto/DPTuner/WOP QSSB/Billet Intakes/Hypermax Tapercore/Terminator HPOS/DI Regulated Fuel Return/FASS/Banks Monster Exhaust 354hp/775tq
dmeis is offline
Old 03-08-2005, 02:26 PM   #3 (permalink)
kilapapipa's Avatar
My Photos: (13)
Interesting, what does a new HPOP run in $$??
REBORN 20 Over on 3/2/11- Pics in Gallary- 2000 F250, Auto, 38r, Full Force 238cc/100%, TE 17* hpop, DP F5,HI,60T,80E,120R,140A, Studs and 910's with DI PR's, ARI TC, JW VB, Walbro 392, TC Lock, Bellowed, In-Tank, Pre-Pump, boost fooler, and RR. Air Dog, SS cover, 6.0 TOC,4" straigt piped and guages, 6637, 203T, coolant filter, 4" Lift on 33's.
kilapapipa is online now
Old 03-08-2005, 03:54 PM   #4 (permalink)
Yep i'm interested as well. How do you ck. the pressure, with what and what should the pressure be ??
[img]/ubbthreads/images/graemlins/eek.gif[/img]
RobertJohn is offline
Old 03-08-2005, 03:57 PM   #5 (permalink)
Right around 450.00 or so. Check with Swamps I think he can get them cheaper.
99.5 F-350 C/C Dually, Stealth HPOP, Full Force Diesel stroked A code injectors, Holset turbo, AEM intake.
Vengeance is offline
Old 03-09-2005, 10:05 PM   #6 (permalink)
It cost me $508 plus the core.
dmeis is offline
Old 03-09-2005, 10:37 PM   #7 (permalink)
The best way may be to install a 3000 psi gauge in the head and moniter the pressure while under power
Detroitnv871t is offline
