skipping feeling when backing up - Diesel Forum - TheDieselStop.com
Old 03-05-2005, 12:46 AM   #1 (permalink)
I feel a skipping feeling once in a while when backing up, no trailer or anything, and it only does it once or twice then its fine...any ideas.. rear diff or something i'm thinking?
01 ford dually, crewcab, long bed, powerstroke, 4x4, billet grill, 83,000 miles,Edge juice with a f..ing attitude, towing a 24' classic dominator xt..with (3) hayabusa's.. 1 goes over 260mph and and 1 goes 230+ on motor and a 7.30 at 200mph no bar bike. Replaced trans with factory upgraded and replaced crank sensor, and rear clutch pack. Also added K/N filter, and MBRP exhaust 4" also bully dog trans guage
project260 is offline
Old 03-05-2005, 12:50 AM   #2 (permalink)
haul_n_horses2's Avatar
My Photos: (17)
Re: skipping feeling when backing up
Do you have the limited slip differential? If so you may need to add a touch of friction modifier.
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2µ Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203º T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
haul_n_horses2 is offline
Old 03-05-2005, 12:53 PM   #3 (permalink)
fordmastertech's Avatar
Check the trans fluid level. If it is low it can start to apply the torque converter when it is not supposed to, especially in reverse.
[img]/ubbthreads/images/graemlins/shrug.gif[/img]
Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
Old 03-07-2005, 11:18 PM   #4 (permalink)
drdenny1's Avatar
That's exactly what mine was doing, check the fluid.
2000 F350 SD 4X4 CC LB Lariat
4"DPPI Turbo back
aFe Magnum
50/80/110 Bill's flip chip W/PMT1,and a DP 120
A-Pillar Autolites Trans/EGT/Boost-GOS Racing
APCM(AIC)
Boost Bleed off
4" Lift W/315's
Dual alt's.
ATS housing
Wicked Wheel
Banks 1.0 A/R housing
ISSPRO TTM
Warn Premium Hubs
J/S IDM
Racor 4500 CCV
ARG SuperPump and Gear
GOS Racing-Head Light Harness
2004 Sprinter 292FWRLS
SOLD: 97 F250HD CC SB 4X4 7.3L E4OD 4.10
drdenny1 is offline
Old 03-08-2005, 12:17 AM   #5 (permalink)
GEM
My Photos: (10)
This may sound dumb but your emergency brake isn't slightly engaged is it?
'01 F250 7.3L PSD 4x4 XLT SD SC SWB Harvest Gold, PMT1(stock)/Tipton 4-pos chip(PMT1), Factory Tech Monster Box, Dieselsite trans filter, Tru-Cool, 3.73 LS, camper/offroad/tow, chrome steps, cab clearance lights, Lund deflector, bedliner, Pro Flaps, Warn 9500# front/rear receiver mounted winch, Tekonsha brake controller, 285/75R16 Yokohama Geolander AT+II's, A-pillar w/ISSPRO EV gauges, ISSPRO Turbo Temp monitor, "Hutch" fuel mods, 'Pooned tank, Airdog, open element intake w/Zoodad, ATS housing, CCV reroute, ITP H/X, JNB reg fuel return and supply w/no CVs & restrictors, AD#8, TC lock, power pedal, manual idle, coolant filter, DPPI T409 exhaust w/3.5" DP, Aeroturbine, Tuff Country 2.5" leveling kit & 4" rear blocks <font color="red">www.gmayle.com</font>
<font color="blue"> Colorado Powerstroke Club </font>
GEM is offline
