My wife's 2000 PSD has had an extremely slow crank since we purchased it about 2 months ago. It always starts but cranks very slow, even after a long drive. I have put a battery tester on the batteries (yes, this tester does apply a load to the batteries) and both batteries were in the green "Good" range but fairly close to the red. This makes me think that the starter is the culprit. I have read several threads where people have had similar symptoms and it turns out to be the starter. My question is, how do I know for sure whether it's the batteries or the starter without using the trial and error method? I don't want to spend a lot of money on the batteries and find out the problem was the starter and i don't want to spend a lot of money on the starter and find out the problem was the batteries. So, what kind of test can I perform that will tell me who the real culprit is? I know I can remove the starter and take it to Napa and have them test it but I really don't trust those bench testers because they don't apply a load to the starter.
Wife's Truck: 2000 F-250 2WD Crew Cab Auto
My Baby: 2004.5 Dodge 2500 Quad Cab 5.9L Cummins LWB 4X4 6-speed. Smarty, Raptor 150, South Bend Clutch purchased and soon to be installed.
I am not an electrical expert, but how old are the batteries? How many miles on the truck? When you load tested the batteries, were both cables off both batteries? The cables need to be off, otherwise one will draw off of the other. I would check the starter cables, and make sure the starter mounting bolts are tight. My first guess is a weak battery. The alternator is charging properly, and the tensioner is in good condition. A tensioner getting weak can really fool you. Hope this helps.
Sold 02 F350 Lariat CrewCab Toreador Red/ Silver DRW LB AT 4X4 4.10 gears, BTS custom chip, and tranny. built BTS and Ford Tough! 859,532 miles
SOLD: 02 F350 Lariat CC Toreador Red, DRW AT 4.10 gears, BTS custom chip, and Tranny 214,550 miles,Built BTS, and Ford Tough!
Sold 94 F350 XLT SC DI DRW 5Speed 314,000
Lifetime Member "BTS BUBBA" Association
"Ain't no feelin like BTS mobilin"
SLAPS Member
Sold 62 Corvair 95 Bus
92 Buick deuce and a quarter
03 Ford Windstar- Granny Hauler
Yes, when I load tested the batteries I disconnected a cable from one of them. What effect would the tensioner have on the electrical system? Not sure what you're getting at here unless you are saying the tensioner squeak can sound like and alternator sqeuak.
The best advice I ever got regarding electical systems of cars & trucks is to fully charge the battery (in this case, batteries, separately and disconnected from the engine) before performing any other test. Twelve hours should do it unless you have some nuclear charger, and anyway, slower is better.
If you can check the specific gravity, do so after charging. Should be above 1.25 and really should be 1.26 or higher.
When you have proven that both batteries are good, hook everything back up and immediately try the starter. If it spins good, then start on the charging system--belt, then voltage with engine running.
One bad diode in the alternator can really louse things up and is hard to diagnose without accurate and precise voltmeter. DAMHIKT.
Chemical batteries suck, but not as BAD as hand cranks and gas lights.
Art
2000 F350 7.3 PSD 4x4 six-pack dually. All Stock.
Ride Rites with "Big Red" on-board Compressor.
DynaTrac Free-Spin conversion.
Hellroaring Battery Isolator for T-145 house batteries.
Flex-A-Lite 900 CFM tranny cooler (for those special 100 Deg./5 MPH-traffic
Florida days) with Magnefine filter.
FleetGuard coolant filter. Mod Photos AE Plots
Sun-Lite slide-in camper.
31-foot Holiday Rambler TT.
29-RLS Jayco TT.
A weak tensioner will not make the alternator charge properly. The belt may not be getting the "bite" on the alternator properly. One member on here went thru a similar situation. He replaced batteries, starter etc. to find out a weak tensioner was the cause of the problem. All of the battery cables need to be disconnected to get an accurate reading. The tensioner can be quiet, or acting normal, but may have lost it's normal performance. How many miles, and the age of the batteries? I would check the voltage output of the alternator, at the back of the alternator with a voltmeter. Try the load test again etc.
SLAPS Member
My '95 cranked slow for a while too. Pulled starter and did a bench test. Starter pulled 80 amps on the bench!!! Put a new gear reduction starter in, never looked back.
2005 F-350 CC, LB, 4x4, Dually, 6.0 Powerstroke, Torqueshift, 4:10 Gears. Gooseneck and rear pull hitches. "Truck Covers USA" roll up aluminum tonneau cover. Putco Boss Running Boards. Aluminum finned diff covers. Bilstein HD shocks. ProComp steering stabilizer. XRF ball joints. NC Hornet CCV mod. RCD egr delete kit. AirDog fuel system. Strictly Diesel's regulated fuel and coolant return lines kits. Amsoil oil bypass (by NUC Motorsports) and homebuilt coolant bypass kits. CFM intake elbow. ARP head studs with factory gaskets and all upgrades. MBRP 304SS "Cool Dual" exhaust system. SCT Livewire tuner with pyrometer. Autometer 'A' pillar gauges (Boost/Trans temp/Pyrometer/Fuel Pressure). 850 CCA Motorcraft Batteries. Using Rotella T-6 synthetic oil. Upgraded degas tank and cap. Hayes deep aluminum trans pan. GoGo Diesel modified direct clutch solenoid. Retro Solutions HID head and fog lights. High idle mod. Jimmi-Jammers. Many other custom features.
Pardon my ignorance, but is 80 amps low? I know the batteries usually have 700-800 cranking amps, but is that what the starter actually draws?
