Snow clogged Air Filter - Diesel Forum - TheDieselStop.com
post #1 of 12 (permalink) Old 12-02-2007, 09:43 AM Thread Starter
Just a heads up on a possible winter situation. The air filter clogged with snow yesterday in my 2001 Excursion. (I don't remember the name for the upgraded air filter, AIS I think.) The symptoms were no power and a rough running engine. I'd driven for a couple of hours in blowing ice crystals that ended up clogging all the little inlets of the filter. The housing itself had some snow in it, but the inlets all had blockages which is what I think caused the issue. I had limped to an interstate rest stop to evaluate options and was able to use the hand dryers in the restroom to blow out and melt the snow.
So is there a modification to the air inlet stream to block snow?
The filter minder prior to the trip had registered some blockage but not the full stop that I saw when I opened the hood.
Thanks for the help.
2001 Excursion, BTS Transmission, DI External Regulator fuel bypass kit, BD-X monitor guage.
jryan is offline
post #2 of 12 (permalink) Old 12-02-2007, 10:10 AM
Re: Snow clogged Air Filter
did you do the zoodad mod or the fender sleeve mod?
there should be a rubber flap in the front that prevents the snow from going up the tube.
if all that's there ,how did the snow get in there?
2001 7.3. Lariat...
muffler delete,Isspro guages,AIS,SCMT 1705,CCV Mod,Zoodad Mod
Lone20 is offline
post #3 of 12 (permalink) Old 12-02-2007, 12:11 PM
To effectively do the zoodad mod you cut the rubber out as well.
Back home we all had twist grommets on the grill and a canvas cover that fit the grill perfectly, from headlight to headlight was covered with the canvas cover. I have herd of guys putting a piece of plastic or a piece of cardboard in a gallon ziplock in the opening of the zoodad mod cut out.
: Early '99 F350 CC LWB 4X4
Annoy A Liberal
Work Hard, Succeed, Live Happy!
Family of 5 saved by Grace.....
strokin_early_99 is offline
post #4 of 12 (permalink) Old 12-02-2007, 02:24 PM
What conditions were you driving in that caused it to clog up? Were you 4 wheeling through snow? I've driven my truck through many snow storms and with the zoodad mod I've NEVER accumulated any snow on my filter. And in those conditions played around in the parking lots full of snow, while no other vehicles were around, and played around close to 50#s of boost. I can see it getting clogged playing around in deep snow causing it to get clogged or maybe perhaps a blizzard, but under normal conditions this would never happen. Please be honest and explain your driving conditions prior to pulling over at the off ramp? Are you in one of the states that are having blizzard like conditions currently?
Danny Om
01 SC PSD Dually (build date 08-00 w/ PMRs), 8" Edge, dual F&R Doetsch aluminum shocks w/ resevoirs, 37" SSR on all 6 tires, 2" (hub & wheel centric) wheel adapters by Fearless Fred Goeske, Fabtech racing track bars.
APC Projectors (HID 10k), clear corners, clear cab lights, clear dually side markers, Amp-Research retractable side-steps, power rear-slider, Snug-Top canopy, billet grill, and chrome truck nutz!
Fully built motor w/ B-codes, GT42R, and Terminator w/ remote IPR HPOS.
Auto Enginuity Pro-Bundle equipped if you need assistance locally.
duallyduty is offline
post #5 of 12 (permalink) Old 12-02-2007, 07:47 PM
cgroveusa's Avatar
From the 02' 7.3 "Diesel Supplement":
Operation in Snow
"Vehicle operation in heavy snowfall or in dry loose snow that may swirl around the front of the vehicle may feed excessive amounts of snow into the air intake system. This could plug the air cleaner with snow and cause the engine to stall."
I experienced this on a NY to Chicago run a few years ago. About 5 hours into the trip (major snowstorm) my air filter idiot light on the dash lit up. Pulled into a rest area and removed air filter which was a solid block of ice. This was with original/stock air box. I haven't experienced this condition with the AIS...yet. But then again, I haven't driven for that length of time in a major snow storm since then either.
I carry a spare filter since then.
Joe
02' F-350 XLT SRW 4x4 RC L/B PSD - BTS Trans - 6.0 trans cooler - Magnaflow 3.5dp to 4" back - AIS w/fender mod - AIC - Turbo-Saver - Stancor GPR - Bilsteins - Autometer Z-series - LL#8 delete - In-tank mod/pooned/pre-pump delete - Dahl 100H - Coolant filter - Helwig Rear Sway - Reese 15k Pro - Prodigy Br Ctrl - Marinco Plug-In - Rhino Liner - Cobra 18WXSTII - Towing 04' 38' CITATION f/w 375SBS 19,600# GCW
06' Mustang GT conv
SUPPORT OUR TROOPS...THANK A VET!!!
Assist Our Wounded Military:
cgroveusa is offline
post #6 of 12 (permalink) Old 12-02-2007, 08:11 PM
FleetMan's Avatar
TYMAR anyone?
Early 99 F250 PSD (XLE4) XLT, Extended Cab, Short Bed, 4X2, BTS Trans/TC, 3.73 Limited Slip, Transfer Flow 48 Gal. Mid-Ship Tank
Western WA - Member since August 2001
FleetMan is offline
post #7 of 12 (permalink) Old 12-02-2007, 08:14 PM
Mine froze once on I70 during the xmas storm 3 or 4 years ago started snowing in St. Louis and didn't stop till the east side of Columbus
2002 F250 Lariat 4X4 PSD Supercab Shortbed
Born 02/02 4" Exhaust Open Intake B100
2003 Monte Carlo SS
fordboy424 is offline
post #8 of 12 (permalink) Old 12-02-2007, 11:41 PM Thread Starter
Conditions were a bit unusual, at least as far as the lenght of time we had. It was a dry loose snow that just swirled. It didn't stick to the road, just billowed up with any passing vehicle. And we had hours of that before it was a problem.
Sounds like the gril cover that's sitting in my garage may have prevented the issue. So I'll be installing it before my next road trip.
Thanks for the replies.
jryan is offline
post #9 of 12 (permalink) Old 12-03-2007, 01:34 AM
Ok, so this is an experience we know to expect when running a completely stock intake system. How about those running aftermarkets? Anyone else have any troubles? Or is it just limited to those running the stock systems?
Danny Om
post #10 of 12 (permalink) Old 12-03-2007, 12:21 PM
RallyGTI's Avatar
On Saturday I towed about 5,000lb on a 150 mile trip with snow accumulations of about 1 inch per hour. Temperatures hovered around 20 degrees F for the entire trip.
I have a zoodad mod on my truck with a stock air box and motorcraft filter. I had the air filter pack up on me about every 40 miles. I carry a spare filter so I pulled over and swapped the filter out. I knocked the snow out of the filter and put it on the passenger floor, by the time the filter had packed full of snow again the filter in the passenger compartment was dry and ready to be used. I noticed that if I was in traffic, the filter seemed to clog up faster than when I had no traffic to contend with.
2002 F250 7.3L 4x4 ext. cab, short bed, auto, 285/75/16 BFG AT, Walker muffler, DP F5, aprox. 100k, race and rally car hauler
RallyGTI is offline
post #11 of 12 (permalink) Old 12-03-2007, 04:19 PM
haul_n_horses2's Avatar
My Photos: (17)
Tailgunner had issues with his air filter becoming a blue block of ice after performing the zoodad mod. However, it seems the 6.4 has this problem right out of the box. Look here. Apparently, Ford did not test the 6.4 in the driving snow we get here in Michigan and points North.
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2 Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203 T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
haul_n_horses2 is offline
post #12 of 12 (permalink) Old 12-04-2007, 01:40 PM
schlepprock379's Avatar
I have the DIY Tymar filter system,I havent had it in snow yet..but I dont see how it could ever clog at all. I used a 4" piece of metel pipe(some use PVC but not me) and Napa air filter that I cant remember the # of,sealed around the filter and the pipe with silicon and you can bet shes breathin clean air....(just my 2 cents worth)
99.5 F-250 Super Duty w/7.3 Powerstroke
4X4 Short Bed/Crew Cab
Magnaflow 4" Turbo back SS Exhaust/5" Tip
DP-Tuner>No-Start,Stock,High Idle,60HP Tow,Decel,80HP Econo,120HP Race,Lope Idle
ATS Housing
HPX Crossover
AIH Delete
Autometer Ultralite Series Gauges(Boost,Pyro,Trans)
Bellowed Uppipes
Rancho RS 5000"s
DIY Tymar/6637
Custom/Spicer Driveline
B.T.S. Valve body
AIH Delete
OverBoost Annihilator
6.0 Trans.cooler
Under construction!
schlepprock379 is offline
