spindle hub seal?? - Diesel Forum - TheDieselStop.com
Old 11-17-2009, 05:22 AM   #1 (permalink)
spindle hub seal??
I'm replacing the universals in front axle(99 f350) and need to install new spindle hub seals, but haven't been able to locate the correct driver. Anybody have any suggestions on where to find the right driver. I would prefer not to spend a couple hundred dollars on a snap on kit that I'm only going to use once. thanks
tinkerr is offline
Old 11-17-2009, 08:54 AM   #2 (permalink)
woodnthings8's Avatar
Here is a homemade tool from the site SuperdutyPSD.com. He also has a reference at the bottom of the OTC tool used for the job.
Ken
Powerstroke Acronyms
TSB Information
woodnthings8 is offline
Old 11-17-2009, 09:14 AM   #3 (permalink)
bigb's Avatar
I got an OTC thru Amazon for $75, now they're even less.
Amazon.com: ford axle seal installer
Brian, Tucson, Arizona
02 F350 4x4 CREW 7.3 140K, AIS, Isspro pyro, boost & tranny temp pillar pod, Dipricol coolant temp, Isspro EV-2 Fuel Pressure & HPOP, Dieselsite boots, coolant & tranny filters & 203* Stat, 6.0 Tranny Cooler, ITP pre pump tank mod, Bellowed Up Pipes, Riffraff Frx, netbook mount with AE, GPR LED, Stancor, Battery Tender & 2 Marincos.
bigb is offline
Old 11-21-2009, 11:31 PM   #4 (permalink)
thanks for the replies, I got'er back together. for anybody doing this, a lesson learned. there is a groove on the inside of the hub, just after the vacumn port for the 4wd, to use as a reference when installing the seal to the correct depth,when using the homemade tool shown in the post above. the front portion of the seal doen't go past that groove, if it does good luck trying to move the seal back out. I ended up destroying the seal and purchasing another. then borrowed the correct tool to install it to the correct depth. Also if you put the seal in the freezer overnight or at least a couple hours the seal installs very, very easy.
tinkerr is offline
Old 11-22-2009, 09:17 AM   #5 (permalink)
bigb's Avatar
I heard about that and that is why I wanted the tool.
Good tip about freezing the seal
bigb is offline
