Stainless Steel Brake Line Problem - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 09-14-2005, 03:17 PM Thread Starter
I got a pair of SS Brake line for my truck it is a 2000 f350. The passanger side brake line fit perfect, but the driverside is a whole different story...The driver side has 2 hardlines, one is the brake line, then the other line is supposedly for a breather or something. Anyone everyheard of this. I will take a pic this after noon so that you can see. 4wheelparts said that I have to have a custom one made.
2000 F350 8" lift w/ fabtech springs, John wood transmission, CST custom tuner By John Wood, Banks 6 Gun Diesel Tuner, 37" BFG AT/KO, Autometer Sport Comp Gauges, 456 gears with a Detroit Locker Mag-Hytec Diff cover & Trans Pan
straitmobin is offline
post #2 of 6 (permalink) Old 09-14-2005, 11:45 PM
Re: Stainless Steel Brake Line Problem
possibly the vent tube for the front axle? some call that a breather
00 F-250, SC, Lariat, 4x4, auto, PSD... Smokes a bit :-)
Pulls
282DC Stratos Bass Boat, JohnnyRude Intruder V6/Renegade 25p 4 blade SS prop... outruns most fish :-)
fast_fisherman is offline
post #3 of 6 (permalink) Old 09-15-2005, 11:05 AM Thread Starter
No, that isnt a hard line, I just want to know if anyone with a 2000 if they have the same problem I do...
post #4 of 6 (permalink) Old 09-15-2005, 11:10 AM
Doesn't sound like I had the same problem, but mine were anything but bolt on. I bought Skyjacker's set. The rear came with the common line before it splits out to the pass & driver side. It had the wrong size fitting on it, so I couldn't use it. The fronts had the correct fittings, but didn't fit into the stock bracket mounted on the frame very well. It wasn't too bad to modify, but I didn't expect to have to do anything just to put on some brake lines.
Are you talking about the front or rear? Mine is a 2000 also, so it's probably similar to yours, but I don't recall seeing multiple hard lines.
2000 F-250 4x4 SC LWB 6 spd, manual hubs, Dynomax muffler, Westach pyro/boost gauge, Tymar intake, Tuff Country leveling kit, RS9000s, Warn fender flares, Reaper Racing Pre-runner Bumper, "Gold" Coolant, 86k and going strong...
Highway Tires - Dunlop Radial Rover AT 255/85R16 on stock XLTs.
Wheelin' Tires - 315/75R16 BFG Mud KMs on 16x8 Weld Evo Renegades.
BigE is offline
post #5 of 6 (permalink) Old 09-15-2005, 11:24 AM Thread Starter
it is the skyjacker front only... Take a look to see if on your driverside has 2 hardlines or not...
post #6 of 6 (permalink) Old 09-15-2005, 01:46 PM
turns out your truck is really a early 99 or was built then. That is one of the small difference in the early build trucks. Skyjacker, makes a specific part # for that truck, you need to return those lines and order the new set. You just simpliy have the wrong one.
Magnumworks is offline
