Starting Problems - Diesel Forum - TheDieselStop.com
Old 11-02-2009, 11:30 AM   #1 (permalink)
Question Starting Problems
This weekend i had some starting problems with my 01 f350.Truck would turn over but not start,waited a few minutes then it would start.I checked the battery connections and found that both neg terminals were a little loose so i cleaned and re tightened them.I also checked the batteries and both checked good.
Well after a little reading here on the forum i read that you need to see around 500 rpm on the tach while starting.I never payed any attention to it before(new to diesel)so i noticed that when the truck didnt want to start i would see round 500 rpm on the tach and 0 when it did start.I do have the new cps and i checked the #30 fuse ad it was ok.The truck has done ok since i have driven it a while with the battry terminals tightened.Is there anything else i need to check?
Shawn
2001 F350 DRW..Stock for now
2004 sprinter 303BHS
camperhaulin is offline
Old 11-02-2009, 04:45 PM   #2 (permalink)
woodnthings8's Avatar
I don't think it takes 500 rpm to start, I think you were reading 500 psi fron the HPOP to the injectors to allow the PCM to tell the injectors to fire?
Ken
Powerstroke Acronyms
TSB Information
woodnthings8 is online now
Old 11-02-2009, 05:57 PM   #3 (permalink)
How cold was it where you're at? It could be the Glow Plug relay starting to go bad, not heating up the glow plugs. Did you leave the key on, but not try to start, until the WAIT TO START light went out? In really cold climates, you may have to do this a couple of times to get the glow plugs hot enough to get the engine going.
short_stuff
Y2K F250 CC PSD Auto, Short-bed Lariat, Woodland Green/Gold, ordered 07/10/99, born 09/12/99, delivered 10/08/99, Access bed cover, Bed Rug, Zoodad mod, Viper Remote Start Alarm, Fumoto valve, 103K somewhat error-free miles (so far) [never back to dealer for anything]
Repairs: CPS, Water Separator Valve assembly, rear axle bearings, VSS, batteries, brakes, alternator, serpentine belt (x2), driver door pwrlock actuator, water pump
2009 VW Tiguan 2.0 l turbo 200 hp gas engine (TDI engine not available for it yet)
short_stuff is offline
Old 11-03-2009, 09:27 AM   #4 (permalink)
I read a lot of post so i maybe wrong!I did notice when the engine turned over but didn't start the rpm showed around 500,but when it does start it stays at zero.
It was 65 deg here when i had the problem so i can rule out cold weather.since i tightened the battery posts it has been starting fine so i hope that was the culprit.
shawn
