Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > 7.3L Power Stroke Engine and Drivetrain
7.3L Power Stroke Engine and Drivetrain Discussion of the 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 07-04-2008, 07:15 PM   #1 (permalink)
starts then stops
My '02 7.3 has 45K miles. Has ran perfectly without any problems, I've owned it since new.
I started the truck, it warmed up for about 5 minutes then just died. It would start, run for a few, then die. I let the truck sit a few days while I got a new fuel filter. Replaced filter. Primed the filter a couple of times. Turned it over, and it started and idled for a couple of minutes then died. Now I cant get it to start at all. It just turn over and over.
vrinner is offline
Old 07-04-2008, 08:14 PM   #2 (permalink)
klhansen's Avatar
My Photos: (85)
Welcome to TheDieselStop
There's a couple of things you should check.
First, pull the oil dipstick and see if you have anything on the stick. If these engines are too low on oil, the High Pressure Oil Pump (HPOP) will run out of oil and the injectors won't fire.
Second, pull the plug on the top of the HPOP reservoir and see if there's oil within about 1" of the cover.
Third, check the batteries. If they're too low, the electronics won't fire the injectors.
Forth, Check the CPS.
Hope that helps.
99.5 F250 PSD Supercab LB 4x4, 6spd, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, Jody's 80 HP Econo PCM (classic version), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check here
klhansen is offline
Old 07-04-2008, 11:27 PM   #3 (permalink)
My Photos: (5)
trucks can smlell fear, that's whiy it won't run
Pocket is offline
Old 07-05-2008, 12:37 AM   #4 (permalink)
Hope that helps.
Thanks for the welcome! I may be hanging out here more often now that I'm starting to have issues. The truck has been flawless for the time I've owned it so I havent really had to search for help. I'm a Ford guy to the bone. My first truck was a 1957 F100, I've owned several Mustangs and still own two.
A couple of questions...
Where is the HPOP resivior? Whats the CPS? Also on your battery suggestion...interesting as the truck doesn't get ran that much and the batteries are a bit low.
vrinner is offline
