Stranded!! - Diesel Forum - TheDieselStop.com
Old 02-04-2009, 08:51 AM   #1 (permalink)
Stranded!!
I own a 1999 7.3L Powerstroke. Monday morning my fuel light came on and not three seconds later it died in the middle of the road. We assumed it ran out of fuel. We were able to have someone bring us some fuel, only to have issues with it cranking. I took the fuel filter out, and it was pretty bad off. Turned the key, let the reservoir fill up with diesel, put the filter back in, and it cranked right up. Drove maybe a mile or two, same thing. I was able to get another fuel filter across the street at a dealer ship. Turn the key, fill up reservoir(I admit I am not mechanically inclined, and I'm not sure what you call the place the fuel filter goes)turn key, crank, drive 2-3 miles. So we were stranded, I finally got a hold of a friend with a big trailer to tow me home. Pulled fuel filter off, turned key, filled up reservoir, replaced fuel filter, crank, drove on trailer (we shut it off this time). Got home, unloaded it, pulled fuel filter off, turned key, filled reservoir, replaced fuel filer, crank, parked it, and it has been sitting in the same spot for two days. If anyone could give a lead I would greatly appreciate it.
ApGlover is offline
Old 02-04-2009, 09:55 AM   #2 (permalink)
i had somethin odd happin to me like this awhile back. i was low on fuel messin around with the chip then all the sudden the truck started missing and all power went, couldn't get it cranked. pulled it home took fuel filter out and tried starting it without fuel filter and bingo it worked. so i thought new filter will do it. got a new filter and put it in same problem truck would run then die. so then i started checking stuff. well i ended up replacing the fuel pump on the frame rail and finally got it to start. you could try and see if it will run without the fuel filter could mean your pump is on the way out if it will run without a filter. i did not run mine long without a filter just about 20 secs. so not sure if that would help you. you can try this...fill up the fuel bowl with fuel out of a can or somethin, then put the top on the fuel bowl, turn the key on let the fuel pump cycle turn the key off and then cycle the fuel pump again and try to start it. keep the rmps up. i would just mess with it sitting still so you don't have to tow it home.
early 99 f-250 315/75/16 3.5 inch fabtech shackle lift,intake,4" exhaust 5" single stacked,DIY t/c lock, billet t/c and shift kit on a fresh rebuild,beans tunes ,4 hella lights, 05 head light, 05 chrome grill,red wire pluged, HID lights 200k
other toys
2008 ltr450
2002 440ex
blandproud is offline
Old 02-04-2009, 10:15 AM   #3 (permalink)
I think pump also...
you can check the fuel pressure here ...
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer"....
Most people come here for the facts ...not a hug ...
action4478 is offline
Old 02-04-2009, 11:08 AM   #4 (permalink)
Could cause to to have air in it too. I'm not really the saavy when it comes to mechanics. When you first turn the key on without the fuel filter in it is real bubble like there is air in the line.
ApGlover is offline
Old 02-04-2009, 11:44 AM   #5 (permalink)
do u guys think it could be a bad cps?
1999 F-350 Dually 7.3 diesel lifted 8.5inches 37x13.50 xtream all terrains
Just Installed a DP Tuner F-5 chip, with stock, Decel, 60 Hp Tow, 80 HP econo and 120 HP performance and WOW!!! k&n airfilter Road Armor front bumber Warn 15000 winch Shift Kit, Beefier tourqe converter. Kenwood Indash Navigation, Sirius Radio, Back up camera, Kodiak Electric Steps HID Conversion Kit..
Next up is Gears!
buzzy12 is offline
Old 02-04-2009, 12:03 PM   #6 (permalink)
I changed that last year. My truck had done sort of the same thing, but it ended up being the fuel pump, so we changed that while we were at it, there was a recall on the CPS for my year truck last year
ApGlover is offline
Old 02-04-2009, 03:03 PM   #7 (permalink)
It may not hurt to change it again to rule it out ..
Rick.....
Old 02-04-2009, 07:11 PM   #8 (permalink)
Sounds like a fule pump to me. If you can check the pressure firts.
2002 EX 4x2 Amsoil front to back with Amsoil oil bypass filtration, Cyclone Power fan, HX oil line, Dieselsite prepump and tank mods, local high performance transmission, MagHytec pans,MBRP 4" exhaust, AFE Stage II, BD EBV exhaust brake, Bright Box, Diesel Turbo Life Saver, Dieselsite 6pos. chip, Trans, EGT, Pyro and water temp gauges, Dieselsite tranny cooler, Dieselsite 203dg t-stat, Dieselsite AIH plug, rerout ccv, Coolant filter, Firestone Ride Rites, hellwig rear sway bar, Garrett BB turbo. Dieselsite hpop filter, Auto Enginuity program. Dieselsite Adrenaline hpop.
skibarefoot is offline
