Strange sound when pulling trailer - Diesel Forum - TheDieselStop.com
Old 06-12-2005, 04:14 PM   #1 (permalink)
OK, I'm just a dumb ole girl and I don't know much about trucks. [img]/ubbthreads/images/graemlins/shrug.gif[/img] I bought a 2002 Ford F250 Powerstroke a few months ago and just started pulling a 3 horse trailer. SOMETIMES, when I am pulling a loaded trailer up a steady incline, in Drive, not Overdrive, my truck makes this weird sound, like it's downshifting but it's not. The RPMs don't changing and it doesn't loose/gain power. It happens at around 2400-2500 RPMs.It's a startling sound. Someone said it might be the turbo kicking in??? It's kind of like a surging sound but the truck doesn't surge. I know I am making no sense. Any advice?
I put it in the shop thinking it was my transmission and they couldn't find anything wrong. Only happens when pulling a load. Is this normal??
barrelsnpcs is offline
Old 06-12-2005, 04:20 PM   #2 (permalink)
Re: Strange sound when pulling trailer
Welcome to TDS!!!
Sounds like to me, you are getting what is called Turbo surge, or turbo stall, this occurs in the RPM range you describe, it is caused by air rushing back through the turbo. There are aftermarket housings you can get for the turbo that will help.
ATS is one of the suppliers.
Is the sound a sort of fluttering noise? or a screatching sound almost like letting air out of a baloon with the end stretched.
This sound is much more noticable under load, and also if you have an aftermarket intake setup it is nearly very noticeable.
Do you have a Chip or any aftermarket equipment? If you get a chance you might put some information in your signature letting us know what you've got.
2000 F-350 NVK5, XLT Island Blue 7.3 PSD 3:73LS Reg Cab LB, STOCK EXCEPT:BTS Transmission,Ummmm... Injectors, Home made HUGE Tymar,TC-Lock Mod, CCV mod, Heater-plug mod,6-Pos "Chip", Autometer Z-Series/ISSPro Gauge pod,407hp/849.1FtLbs
http://powerstrokecommunity.com
1/4 ---13.686 @ 96.69
1/8 ---8.625 @ 78.17
60' ---1.877
#51
MrPlowJr_EZ_V is offline
Old 06-12-2005, 04:39 PM   #3 (permalink)
If you are in a hard pull and the truck heats up and reaches a hotter than normal temperature your fan clutch will kick on and run for about a minute to a minute and a half,which helps to pull more air through the radiater fins to help cool your anti-freeze to a safer temperature and then it will shut off until the temperature goes up again and it will cycle on and off again.It is controlled by a thermostat and when it kicks on it will sound like a jet airplane is under your hood.Also put as you mentioned a downshift with no change in pulling or speed change.
"Real Trucks Don't Have Spark Plugs"
2000 F250 Lariat Crew Cab, 4x4
A Few Mods To Make It Better than Stock
"The Smoke Don't Mean Its Broke!"
Bushwakd is offline
Old 06-12-2005, 04:41 PM   #4 (permalink)
Thanks for the "Welcome". Are you saying that this sound is normal and the housing will help muffle the sound? Or will the housing stop it from doing this? I don't have a chip or other aftermarket things on it except running boards. It's a 2002 Ford F250 2WD 4D with Auto transmission.
Old 06-12-2005, 04:50 PM   #5 (permalink)
If the sound appears when in a hard pull and then goes away shortly thereafter it is probably your Fan Clutch cylcling on and off.
Bushwakd is offline
Old 06-12-2005, 05:08 PM   #6 (permalink)
If this infact is the problem, and sound you're hearing, then it will prevent the sound not by muffeling it, but it is a ported housing which will releive pressure imbalance.
Honestly without any aftermarket equipment, I think this sound would be barely noticeable.
These housings can be a little pricey if you're not 100% sure that is the sound, I would hold off, and perhaps get a second opinion.
60' ---1.877
#51
Old 06-12-2005, 05:26 PM   #7 (permalink)
If it sounds like it downshifts but the RPMs do not change, the first thing I would think is the fan clutch. When it kicks in it is loud (sounds like a downshift or a small jet under your hood) and if you aren't ready for it you will almost jump out of your seat (at least I do because I don't here it that often). This may not be what it is but getting used to this normal sound (fan clutch kicking in) is a whole lot cheaper than changing out the turbo housing.
Joe
P.S Welcome to the site and keep us posted on what you find out. I hate never hearing the end of the story.
2002 F350, Crew Cab, 4WD, ISSOPRO Gauges,
3.73, Auto, 2wd low range mod, No door dinger,
Interior lights off switch, Zoodad Mod,
Extra Trans Cooler, Before coolers trans fltr,
Coolant fltr, Crimestopper remote start/alarm
Oil Guard Bypass, Air horns
MOUNTAINMAN444 is offline
Old 06-12-2005, 05:28 PM   #8 (permalink)
HoneyShucks's Avatar
"SOMETIMES, when I am pulling a loaded trailer up a steady incline, in Drive, not Overdrive, my truck makes this weird sound, like it's downshifting but it's not. The RPMs don't changing and it doesn't loose/gain power. It happens at around 2400-2500 RPMs.It's a startling sound."
No question about it. Normal operation of the fan clutch locking on to cool her down. Sounds like a jet headed up your exhaust [img]/ubbthreads/images/graemlins/eek.gif[/img]
2001 Ford F-250 PS, CC, 2/w drive short bed, auto(BTS upgrade), Banks Stinger Plus and exhaust brake, TurboSaver, HX,Hutch mod/pooned, K&N FIPK, Mag-Hytec trans and diff pans, Cyclone fan, doodad, Bilstein shocks, Air-lifts front and rear, dp-Tuner F-5 chip, Fleetrite/203therm, fuel regulator shim, GOS headlight harness/silverstars, Bob's coolent filter, Rotella Syn w/single by-pass.
HoneyShucks is offline
Old 06-12-2005, 05:57 PM   #9 (permalink)
I think a couple of you hit the nail on the head! I think it is the fan clutch. Yes, I do about jump out of my skin! Then, my knees started rattling because I was alone, pulling 3 horses, 150 miles from home, thinking my transmission was going! And it does sound like a jet under my hood or a downshift. And it's always at the top of a steady incline. Only last for a few seconds, too. THANKS so much for the information. I feel better and I can hit the road again without being paranoid! Other than this, this truck so far is a pulling machine! THANKS SO MUCH for the peace of mind.
Old 06-13-2005, 07:48 AM   #10 (permalink)
Why not in overdrive? These trucks are designed to tow in overdrive. If the transmission isn't shifting frequently you can tow in overdrive and save fuel.
Casey_1 is offline
Old 06-13-2005, 08:25 AM   #11 (permalink)
JakeSpoon's Avatar
LOL
good job barrelsnpcs.
I too have always wondered what that sound was, just never asked anybody. I figured it was something like that...but never asked.
1999.5 F250 CC 4X4 PSD Lariat White over Gold BONE STOCK w/ 143950 miles
JakeSpoon is offline
Old 06-13-2005, 12:31 PM   #12 (permalink)
Dittos
JakeSpoon
I was thinking the same thing...
2001 PSD Super Duty F350 XLT 2WD SRW Shorty 4SPD. BD Performance Trans.& Conv. K&N Air Filter,Line-X, Mag Hytec Diff. Cover, BD-Exh.Brake, Elec.trans.cooler,3-gauges/A pillar. 2003 Alpenlite 32ft Augusta 5er.
Firestone Air Bags. Michelin XPS LT 235/85R 16/E
1 Choc. Lab.
Dozer Don is offline
Old 06-13-2005, 12:53 PM   #13 (permalink)
Once the sound starts, how long does it stay on? Should stay on for a about a minute. If the sound is coming and going every second or so, then this is a known problem.
Had my 2002 fixed about two years ago for the rapid cycling. Now it comes on and stays on for around a minute.
Tim
2002 XLT Crewcab 4x4 F350 PSD Arz Beige. American flag bug deflector (gotta show my colors), Teconsha Prodigy brake controller, 28' Keystone Couger 5er. Pre pump mod (thanks Hutch), Walker BTM, upgraded IH Up-Pipes and intercooler boots from Riff Raff Diesel
mitley_350 is offline
Old 06-13-2005, 01:57 PM   #14 (permalink)
JakeSpoon's Avatar
yeah, mine only does it for a minute or less.
And, only on long hauls,(never notice it in town)
usually when im stopping or at a dead stop.
Old 06-13-2005, 02:58 PM   #15 (permalink)
avi
[/ QUOTE ]Because she is climbing a hill and her RPM's are in the 2400-2500 range which is great for climbing. It sounds like she is taking it out of overdrive and driving the truck perfectly [img]/ubbthreads/images/graemlins/smile.gif[/img]
'99.5 F250 Lariat 4x4 7.3L PSD, Crew Cab, Short Box, Auto, 3.73LS, Mastercraft Courser C/T LT285-75-R16, Magnaflow 4" exhaust with 3.5" DP, 6637 open filter intake, AutoMeter Sport Comp pillar mount gauges, DP Tuner F5 with 40t, 60t, 80econ, 120race, Hella 550 driving lights, Tru-Cool Max tranny cooler, 205k miles, HD4R100 tranny, Zoodad. Airbags on back, leveling kit on front.
avi is offline
