SuperChips Diagnostic Codes - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 07-18-2007, 06:42 PM Thread Starter
Maybe I am a little slow or even retarded...HAHA but I can not find out where to look up the codes Brett's Truck is throwing...its the 2000 F350. Can anyone give me a website or link or something???? It was throwing 12 codes and when I cleared it it threw 2 right off the bat.... 0113 & 0475 THANKS for the help!
95 F250 PSD-auto, ext cab, 2wd, k&n drop in, faubiam motorsports trans.
02 F350 PSD-4dr, 4X4, drw, auto, line-x, sirus sat. radio, single position TWildman Chip, Napa 6637 Open Air Element, de-clawed, sonnax and tricumulator, ebpv delete, faubian motorsports trans.
pawsranch3 is offline
post #2 of 6 (permalink) Old 07-18-2007, 08:42 PM Thread Starter
Re: SuperChips Diagnostic Codes
i am going out to dinner but i will post codes when i get home
i apreciate any and all help yall!!!
thanks
post #3 of 6 (permalink) Old 07-18-2007, 09:59 PM
klhansen's Avatar
My Photos: (180)
Look HERE for DTC help.
), AIS,
regulated return,
klhansen is offline
post #4 of 6 (permalink) Old 07-18-2007, 11:17 PM Thread Starter
i am throwing a lot of codes relating to the ipr, where is this located at?? my symptom are as i am driving i lose fuel and power but will regain it intermittantly, yesterday the truck died and had to have it towed to my house where it restarted. today while driving i lost power quite a few times but regained it, however the truck died again and i had to have it towed... does this sound like the ipr????
post #5 of 6 (permalink) Old 07-18-2007, 11:28 PM
Sounds more like a CPS to me. Could be an IPR. When a CPS goes, there is no telling what codes you will get, sometimes none.
Look here , for the CPS, and here for IPR rebuild.
To find the IPR, look on the back of the HPOP reservoir for the lightweight tin nut, that is where it is. If the nut is loose, that may be your only problem.
If you buy a CPS (you should keep a spare in the glove box), in a hurry, go to a local Ford house, $27.00, have time order from here. , less than $16.00 plus shipping.
Andy
Early 99 5-98, F350 extended cab, DRW LB 245,000 miles and counting, Hood insulation delete (Soaked with fuel), Hutch mod, Harpoon mod. Otherwise, pure stock (for now)
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
arisley is offline
post #6 of 6 (permalink) Old 07-19-2007, 12:53 AM Thread Starter
i just replaced the cps yesterday!!!still having problems
