Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > 7.3L Power Stroke Engine and Drivetrain
7.3L Power Stroke Engine and Drivetrain Discussion of the 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 01-31-2007, 09:46 PM   #1 (permalink)
Switching to Synthetic
I want to Switch to Synthetic, From Dino. I'm running Rotella 15/40 And want to switch to Rotella Synthetic, do I have to worry about the remaining Dino left in the system after draining the pan, I'm guessing it is not good to mix them? If it was you would think we would have heard of someone running something like a 50/50 blend of dino/syn by now? Thank you SPIKE481
2002 F/350 Super Cab XLT Lariat trim 6spd SRW 4x4 3.73 posi 7.3 LUBERFINER 272-C AUXSILERAY OIL FILTER, MBRP 4"409 stainless steel exhaust AIS,
Spike481 is offline
Old 01-31-2007, 10:25 PM   #2 (permalink)
Re: Switching to Synthetic
No its fine. Go ahead and switch over.
wells
mtnbkr132 is offline
Old 02-01-2007, 08:48 AM   #3 (permalink)
make sure you change out your oil filter at the same time.
2k F250 XLT CC 6sp PSD, 3.73 LS axle, Superchip, W-D Turbo Brake, Memphis speakers & 5ch amp, WD-Pyro & Boost gauges, Rechargable MagLite, quick disconnect jumper cables, CAT batteries, ARE tonneau,
"unaable" on the tailgate!! New door actuators!!
T-304 Stainless exhaust turbo back, Southbend clutch
Tina is offline
Old 02-01-2007, 11:50 AM   #4 (permalink)
SmokeyWren's Avatar
My Photos: (33)
Your engine holds about 16 quarts of oil, but only 15 will drain when you change the oil. The other quart is in the high pressure oil pump (HPOP) reservoir, and it won't drain.
But mixing 15 quarts of synthetic with that one left-over quart of old oil is the normal way to change the oil to synthetic. Only real sticklers for detail will bother to suck the oil out of the HOPO reservoir before they pour in the fresh oil. [img]/ubbthreads/images/graemlins/phoney.gif[/img]
SmokeyWren is offline
Old 02-01-2007, 01:03 PM   #5 (permalink)
There isn't a problem switching back and forth from synthetic to dino is there? I like the Rotella synthetic in the winter, but regular dino works great for me and the budget in the summer. Any thoughts? I thought I have heard of people doing this without problems, but just want to make sure!
Thanks!
*2002 Crew Cab 4X4, XLT Lariat, DP Tuner 80hp/Econo, AutoMeter pyro,boost,trans, AIH delete, AIS, Zoodad, Walker BTM, Sonnax/tricumulator, Magna-fine, Amsoil Torque Drive ATF, Tekonsha OTA 19000lbs trans cooler, 203 stat, Coolant filter kit, Rotella ELC, DrawTite brake controller, AIC module, 172,500 miles, Cen-Pe-Co 15W-40, Stratapore oil filter, Michelin LTX M/S 285/75/16, Monroe Reflex shocks, intercooler wrap removed, Roll-n-Lock
weitekampt is offline
Old 02-01-2007, 07:40 PM   #6 (permalink)
I'll be making the switch Friday, if I wanted to go trouble of getting the rest of the oil out what would be involved? Spike481
Spike481 is offline
Old 02-01-2007, 08:08 PM   #7 (permalink)
SmokeyWren's Avatar
My Photos: (33)
I don't think so. I've done it more than once. Rotella T to Amsoil 15w40 synthetic and back to Rotella T. And Rotella T to Delvac 1 and back to Rotella T.
My only surprize was when Blackstone told me my oil change interval of 5,500 miles didn't change just because I paid more for synthetic oil. [img]/ubbthreads/images/graemlins/crazy.gif[/img]
Old 02-01-2007, 08:14 PM   #8 (permalink)
I can't find the lower weight oils in my area, so I guess I'll give this Syn, stuff a try for the winter Spike481
Spike481 is offline
Old 02-01-2007, 08:44 PM   #9 (permalink)
Powerstrokedogg's Avatar
Send a message via ICQ to Powerstrokedogg
im running the 5W40 rotella right now and this stuff is awsome for cold climates [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
i don't know of any problems switching back and forth, thats what i plan on doing
2001 F-350 7.3L 4X4(ESOF) CC LWB 4R100 4X4, WIX 46637 open element air filter, Wicked Wheel, walker BTM, 203* Tstat, IC tube foil removed, coolant filter, AIH removed, 08 aluminum finned rear end cover, DP tuner 80econ 140smoke high idle,Phantom gauges, ATS transmission,ATS deep trans pan, 5 star torque converter, V10 trans cooler, 4" MRBP SS downpipe, twin 4" stacks
1989 F-250 6.9L IDI E4OD 500,000+ miles(sold)
1982 VW rabbit 1.6L diesel
Powerstrokedogg is offline
Old 02-04-2007, 04:24 AM   #10 (permalink)
Well I made the switch, WOW what a differences, The truck runs a lot quieter and seems to start a lot easer with temps getting close to zero, Do you think I will see the same performance running just a lower weight Dino ?? Spike481
Spike481 is offline
