Symptoms of bad IPR and ICP sensor - Diesel Forum - TheDieselStop.com
Old 02-12-2009, 12:09 AM   #1 (permalink)
My Photos: (14)
Send a message via AIM to edub32
can anyone tell me the symptoms of each and how to trouble shoot? I have the location of the IPR and will be cleaning it tomorrow and is there anyway to tell if the ICP is bad. BTW, my truck sputters about 3 miles after driving it and eventually stalls. might start up and run like crap. barely make it home stalling in the driveway.
2001 F350 7.3 SCLB 4x4 Off-Road SRW
- DP Tuner, Tymar intake, 35" BFG Mudders on 16x10 Mickey T's, Superlift 6" lift, DiPricol 3 gauge Pillar, 4" SS DP to 5" sidepipe to 6" Chrome tip, WW, Panasonic Deck with 4xInfinity References, Overboost Elim., CCV
edub32 is offline   Reply With Quote
Old 02-12-2009, 04:18 AM   #2 (permalink)
rjs82vette's Avatar
I know if you pull the ICP plug and it is covered in oil then it is bad or going bad.
2002 Ford Excursion Limited 7.3L PowerStroke Turbo 4x4, Banks Power Elbow, Banks Quick Turbo, Banks Big Head Wastegate, Banks Six Gun Tuner, Banks 4" Monster Exhaust, Banks Compressor Wheel, Superlift 6" Suspension (all Springs), FASS Fuel System, Diablo Predator w/ custom Granatelli Program, MAC Cold Air Intake, 37" Procomp XMT on 20" Rims,
2006 Mecedes e320 CDI
2006 VW Jetta TDI
and some other toys
rjs82vette is offline   Reply With Quote
Old 02-12-2009, 10:43 AM   #3 (permalink)
My Photos: (14)
really need to location of the ICP sensor so i can fix it so if you have a picture/diagram that would be helpful PLEASE chime in
Old 02-12-2009, 11:12 AM   #4 (permalink)
Its on the L head ,,next to the lifting ring ,,three wire plug....
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer .Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
action4478 is offline   Reply With Quote
Old 02-12-2009, 11:20 AM   #5 (permalink)
Maintain's Avatar
You need to monitor your ICP and IPR Duty Cycle.
450-500 PSI of ICP to start, 550-750 to idle, and should ramp up into the 2,000's when getting on it.
IPR DC should be around 11 or 12% at idle and ramp up as well into the 20's or 30's as you get on it.
2001 F250 CC/SB Platinum
11.62 @ 115.79
SWAMPED
Maintain is offline   Reply With Quote
Old 02-13-2009, 09:49 AM   #6 (permalink)
hey when i replaced the icp sensor due to a code sayin it was bad i still experienced rough idle symptoms and when i unplug the icp sensor while its still running it will idle fine??
what could this indicate as being bad ?
there was also one more sensor down in the front of the hpop infront of the cooling fan that when itook it out it was filled with sludge dirt like stuff i cleaned it out but there was soo much of it? what do you think this could mean?
05 F 250 XLT extented cab PSD, guages,smoked led tail lights,roof lights, and mirror lights , SCT Xcal 3 innovative X street tune, silver line cool duals, mtx thunderform encolsure with two 10's, alpine deck. 3" rough country lift.
96 F250XLT heavy duty, ext cab, PSD 5-speed, 4:10's/limited slip-so far homemade tymar intake with big filter ,diy stage 1's, ts 6 pos chip, 4 inch turbo back to 5 inch slash cut stacks, pyro and boost guage.reverse glow guages, replaced clutch with a LUK replacement,garmin street pilot, sirius sat radio, Alpine Cd player, Alpine Type R 12" sub, sony xplode amp in custom center console, diamond plate trim and side steps, Visor, bug sheild,
SOLD I sure do miss it !
CapeCodF250PSD is offline   Reply With Quote
Old 02-13-2009, 09:57 AM   #7 (permalink)
That sounds like you Exhaust Backpressure Sensor. It can get plugged and sometimes the tube from the ex. manifold to the sensor gets plugged also.
I replaced my ICP also and my truck runs better when its unplugged. Looking forward to an answer.
2006 KR, CC, LB, 4x4, 6.0 moonroof, power rear slider, dual alternators, Pop-Up gooseneck ball, DR leveling kit, 70000 miles, 285/75/18 Toyo ATs
12/98, CC, XLT, LB, 4x4, 7.3, 6sp, '06 front end, 4" front springs, Bilsteins, DiPricol Pyro,Boost and Fuel Gauges, 35" Toyo, SouthBend Con-O, 197,000 miles, 4" exhaust, Performance Friction rotors and pads, DP F5 chip, RedHead steering box
BWD Turbonetics .84 Quickspool Turbo/Spearco
EBPV Deleted
Dieselsite BRV+, Intercooler boots
Banks Tubes
Terminator
ITP Reg. Return, Intank, and Delete
2008 Hudson 7 ton GN
2002 JCB 212s
2004 A300 Bobcat
barnbuilder is offline   Reply With Quote
Old 02-13-2009, 10:00 AM   #8 (permalink)
so is there a way to clean it or replace it and the tube the sensor seems like it went in the front of the hpop i looked at this a few weeks ago...
we just replaced a valve cover harness the other night the cleared up the power issues (one of the plugs was undone) but it still has the rough idle... so even though i unplug the icp sensor you still think that the back pressure sensor is plugged?
Old 02-13-2009, 10:04 AM   #9 (permalink)
Maybe we are on different things. EBP sensor is on front of engine between fan and front of block. Is this what you are talking about.
EBPV Deleted
Banks Tubes
Terminator
2002 JCB 212s
2004 A300 Bobcat
Old 02-13-2009, 10:05 AM   #10 (permalink)
There is a link around here with a pic and labels.
EBPV Deleted
Banks Tubes
Terminator
2002 JCB 212s
2004 A300 Bobcat
Old 02-13-2009, 10:14 AM   #11 (permalink)
yeah i just found it sounds like it could be an issue bec we replaced the icp on the driver side head bec it said it was bad if u unplug the icp it idles smooth how ever we did remove the ebp and looked at it it was completly clogged i just called my freind and i am gunna have him unplug it and let me know if it runs good again it sounds like it could be based on the symptoms i am seeing?
anything else u think might be wrong
thank you very much
Old 02-26-2009, 09:16 PM   #12 (permalink)
I'm having the same problem. Once the engine warms up I have a rough idle but it smooths out when I disconnect the ICP. I hooked up my programmer and it showed the injector pressure was low at idle once the truck had warmed up. I'm going to replace the IPR this weekend to see if that fixes the problem. If that doesn't work I may try replacing the injector o-rings. Somethings causing the idle pressure to be low - I figure it's either a sticking IPR or o-rings leaking.
2001 X, PSD, 7" DR lift, 37" PJ Dirt Grips, Procomp Extreme Alloy wheels, 4.56 gears, Dynatrac Free-spin hub system, Diablo Predator , Banks 4" exhaust with Power Elbow, Kodiak Sidewinder steps, Autometer guages.
VX23Hokie is offline   Reply With Quote
Old 02-28-2009, 01:57 PM   #13 (permalink)
I replaced the IPR. Runs great now.
Old 03-01-2009, 05:18 PM   #14 (permalink)
My truck has the same symtoms, idles rough and when unplugging the ICP it smoothes out. I'm waiting on my ICP from ebay but sounds like this may not be the fix. How much $$ is the IPR and where is the best place to purchase?
2000 Crew Cab 4WD
Elite diesel chip, BHAF
4 inch dual exhaust
Quadzilla, WW, 6.0 trans cooler
Mr. Jimmy is offline   Reply With Quote
Old 03-01-2009, 09:08 PM   #15 (permalink)
I picked up one on ebay (brand new/in box) for about $100.
Currently Active Users Viewing This Thread: 9 (0 members and 9 guests)
