Symptoms of a Bad/Weak fuel injector - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 08-21-2009, 02:26 PM Thread Starter
Send a message via AIM to rpenkola250
My truck has not been running the way it should or the way it used to run. It has been like this for about two months now and I can't seem to figure out what it is. I was kind of thinking it could be a weak/bad fuel injector(s). Does anyone know what the symptoms of a bad/weak fuel injector are?? Any help would be appreciated
Early 1999 Ford F-250 ECSB, 5" turbo-back exhaust, aFe stage 2 intake, 2" lift, Bully Dog 6 bank 4 position chip, New Injectors, etc.
rpenkola250 is offline
post #2 of 9 (permalink) Old 08-21-2009, 05:08 PM
Todes's Avatar
Have you ever put some diesel kleen in your truck?
Power Service Products, diesel fuel additives, prevent gelling, clean injectors, disperse water, boost cetane, reduce emissions, improve fuel economy
I run it every now and then in the summer, and full time in fall, winter, and spring. Cheap fix if it is dirty....may take 2 or 3 tanks.
7.3L Stroken 4 life!!!
STOLEN 12/14/14
- Recovered 12/16/14 (let the rebuild begin): 2002 F-250 4x4 7.3L Powerstroke 240K(12/2014) (Custom Headache Rack with Bed Rails, lost to theft)
Todes is offline
post #3 of 9 (permalink) Old 08-21-2009, 06:51 PM
jakebeefsteak's Avatar
What are your symptoms. Louder at idle? Louder all around? Low Power? Smoke or hard start?
I agree with Todes. Do you use a fuel additive? I have tried a few, but feel mine likes the Stanadyne.
I also agree it takes 1-3 tanks to hear and feel the difference.
Early '99 F350 Supercab DRW 4x4 Handshaker; BD Exhaust Brake; BD Gauges; BD 90hp X-Power Chip; 4" Turbo Back Exhaust; IC Foil Delete; Wicked Wheel; Banks Quick-Turbo Housing; Banks Big Head Actuator; Afe Stage I; Zoodad Mod; Dual Optima Red Tops; Dieselsite Coolant Filter, Housing & 203 Stat; Ranger Heater Core Valve; Rear Firestone Airbags ; Monroe Reflex Shocks.
jakebeefsteak is offline
post #4 of 9 (permalink) Old 08-24-2009, 01:06 AM Thread Starter
Yes i use additive faithfully, and have tried several kinds. I have been through over 3 tank fulls of diesel since this has started...back to the symptoms, yes it has pretty much everything you listed
post #5 of 9 (permalink) Old 08-24-2009, 10:22 AM
Todes's Avatar
the noises are hard to diagnos with out hearing them.....lets start with the smoke.
when does it smoke?
What color is the smoke?
How long does it smoke for?
STOLEN 12/14/14
Todes is offline
post #6 of 9 (permalink) Old 08-27-2009, 01:03 AM Thread Starter
If it sits all night and I start it in the morning, it is pretty hard to start and when it finally starts the engine runs real rough and puts out a ton of white/grey smoke. after about 3 minutes the smoke dies out. The glow plugs are brand new and it is middle of summer, not winter time. Even if the truck sits for like 5 hours and i go to start it, it puts out a ton of smoke. I also constantly get a light stream of black smoke everytime i step on the gas. It sounds like it has a miss, but no one can figure it out
post #7 of 9 (permalink) Old 08-27-2009, 01:28 AM
Kanman's Avatar
First thing I would suspect would be the under valve cover harness. Pull the valve covers and check the harness, very common on these trucks for them to become unplugged, or burned up. While you are there "watch" the injectors squirting oil with the truck running. If you see one that isn't squirting oil you have found a bad injector.
Kanman is offline
post #8 of 9 (permalink) Old 08-27-2009, 08:19 AM
Flywheel's Avatar
This is likely two different issues. On the start - just because the GPs are new, does not mean they are working. Check the GP relay and that batteries.
The smoke during running could be many things including a turbo going south.
Also, how's your oil. Was there anything done recently about the tie the problem started?
Might want to find scanner and run a CCT.
Trail Boss Replacement Bumpers, Tool Box, Headache Rack, Full Length Running Boards, BFG AT/KO 285/75x16E, 2003 Cup Holder, Marinco Heater Plug, Weather Tech Rain Vents / Hood Guard, B&W GN Hitch, X-Springs, Rear 4" F350 Blocks, Hellwig front and rear sway bars, Airlift / Wireless, Duraflaps
Isspro A-Pillar Gauges, Isspro TTM, Ford AIS, Magnaflow 3.5" DP - 4" Exhaust, Garrett GTP38R Turbo, Turbo-Master, High Flow Outlet, Non EBV Pedestal, IH Up-Pipes, DS 203 degree Stat, OA, BTS Tranny, 6.0L Tranny cooler, DP-Tuner F6, FRX, Cass Stage 1s, T500 HPOP, DieselSite HPX
99 F-250 CC SB 4x4 7.3 White
Ranch Truck, Ranch Hand brush Guard, Original Cup Thrower, DP-TUner F6, 4" Turbo Back Magnaflow, AIS Intake, 6.0 Tranny Cooler, Ford 4R100HD, CM Flatbed
Autoenginuity
Flywheel is offline
post #9 of 9 (permalink) Old 06-01-2010, 11:29 AM
I just went thruogh similar ploblems with my 99 psd. It started ok but lacked power and there was a noticible miss at low rpm. I would check your valve cover wiring harness. Start the truck with the valve covers off and check the oil spit on each injector. Compare it to the rest of them if one is different than it is more than likely that injector. Also with the engine running you can pull off the electrical connector on each injector one at a time and see if one injector doesn't make a difference. Sometimes these tests can be more difinitive that trusting a dealer to screw you over. I had ford tell me my IDM was bad 2 times after I replaced it with one I bought from them. In the end I bought a set of injectors installed them and the truck runs great. Good luck
atatarian is offline
