Synthetic Transmission Fluid - Diesel Forum - TheDieselStop.com
Old 06-14-2006, 10:28 PM   #1 (permalink)
I recently purchased a 2002 PSD 7.3 F-350 current mileage is 41K
My question is... Is there a way to tell if the transmission has Synthetic or Mercon ATF transmission fluid?
samyosemite is offline
Old 06-15-2006, 12:45 AM   #2 (permalink)
Flywheel's Avatar
My Photos: (6)
Re: Synthetic Transmission Fluid
Hi -
I assume your question is whether the tranny is filled with Synthetic or Dino ATF (hopefully it is Mercon).
without running tests, it is hard to tell.
If you try to cook it, the dino will burn easier - but I think it would be easier to refill the tranny with whatever you want....
Unless you know the history - might be a good idea anyway. Flush out and refill with dino - you can always switch to synthetic..
99.5 F-250 CC LB 4x4 7.3 Red New Pics 1/5/10
Trail Boss Replacement Bumpers, Tool Box, Headache Rack, Full Length Running Boards, Bilstien Shocks, BFG AT/KO 285/75x16E, 2003 Cup Holder, Marinco Heater Plug, Weather Tech Rain Vents / Hood Guard, B&W GN Hitch, X-Springs, Rear 4" F350 Blocks, Hellwig front and rear sway bars, Timbrens, Duraflaps
Isspro A-Pillar Gauges, Isspro TTM, Ford AIS, Magnaflow 3.5" DP - 4" Exhaust, Garrett GTP38R Turbo, Turbo-Master, High Flow Outlet, Non EBV Pedestal, IH Up-Pipes, DS 203 degree Stat, DS Boost Relief, BTS Tranny, 6.0L Tranny cooler, DP-Tuner F5, DieselSite HPX
99 F-250 CC SB 4x4 7.3 White
Ranch Truck, Ranch Hand Bumpers, Original Cup Thrower, B&W GN Hitch
Autoenginuity
Flywheel is offline
Old 06-15-2006, 01:38 AM   #3 (permalink)
When I buy a used truck I service EVERYTHING right away unless I get detailed service records with the truck. You never know how it was treated in its past life. So you might as well start off on the right foot.
Mine: 2003 7.3L F350 Lariat Crew Cab Long bed 4x4, 6" RevTech Suspension lift w/ 37" Toyo MT's, AMSOIL fluids front to rear, AMSOIL BK-11 Single Bypass filter, all else is stock (for now)
Hers: 2003 7.3L Excursion Limited 4x4, 6" RevTech suspension lift, 35" Toyo Open Country MTs, 4.10 gears, AFE Stage 2 intake, Edge Juice chip with Attitude monitor, 4" MBRP turbo back exhaust, ATS Compressor Housing, AMSOIL fluids front to rear, AMSOIL BK-11 Single Bypass filter, custom rear driveline by Driveline Tech.
Ours: Tahoe Transport 2700 Toy Hauler
jamjriii is offline
