tachometer not working right - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 07-11-2006, 08:06 AM Thread Starter
I got in my truck this morning and the tachometer doesen't work until I get above 1500 rpm any suggestions early 99
Early 99 F-350
5" straight pipe,overboost 4 way chip, rebuilt auto trans, guages,
beerman24 is offline
post #2 of 3 (permalink) Old 07-11-2006, 12:40 PM
Re: tachometer not working right
Just guessing but the factory tach is fed from the pcm reading signal from the cps, eliminate the cps since the truck does start and eliminate wiring issues between pcm and tach since it does work over 1500rpm. Sounds like the gauge has gone south.
Alan -
2001 F-250 4X4 Ext-Cab 3.73
Tools: AutoEnginuity; Homemade UVC breakout Pigtail
Fluids: Rotella ELC; DELO 400 15W40; Royal Purple MAX ATF & MAX Gear
amiller93 is offline
post #3 of 3 (permalink) Old 07-11-2006, 04:29 PM Thread Starter
thanks for the tip I will try that and see what happens
Early 99 F-350
