Testing IDM and IPR - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 03-08-2006, 08:16 AM Thread Starter
Testing IDM and IPR
I've got a crank but no start condition that's not the CPS - Looking for a way to test / verify the IDM is good and also test the IPR.
I've got the AutoEngunity code scanner program coming (did I need the Ford extended piece??) I'm assuming that will show the pressure from the sensor on the head and if it's over 500 PSI that will clear the IP regulator? But what can I do to test the IDM? Is there something the scan tool will tell me if the IDM is good or bad?
In reading the symptoms the IDM usually fails on 1 bank of cylinders - mine is totally dead.
Thanks in advance.
99 F250 Crew Cab, Diablo extreme chip, Amsoil Air filter, Full Autometer guages on A-pillar mount. Modified Dynomax - downpipe back 4 exhaust 300hp, 600 ft-lb tq
bwiencek is offline
post #2 of 5 (permalink) Old 03-08-2006, 08:39 AM
Re: Testing IDM and IPR
injector BUZZ test will tell u if the idm is working or not.
97 f350 cc 4x4, srw ,tde1, 4.10 gears,head studs w/ factory gaskets' bts tranny mobil 1 synthetic diesel site full pull injectors h2 turbo, 02 hpop ,twin tymar intake ,beddins custom fuel system ,custom ladder bars,turbo life saver,dead kitty, ,dp tuner 4 position chip,hypermax innercooler,oil filler extension,,maghytec pan,4inch exaust w/ 4" stacks, aux tranny filter,dual aux tranny coolers, autometer a-pillar 3gauge,295 nitto at's,4inch lift,ranchhand bumpers front&rear
If you are reading this, THANK a teacher. If you are reading this in ENGLISH, THANK a soldier!!!
scottginfla is offline
post #3 of 5 (permalink) Old 03-08-2006, 10:19 AM Thread Starter
I'm assuming that's an option within the AutoEnginuity application to set the PCM into this test?
bwiencek is offline
post #4 of 5 (permalink) Old 03-08-2006, 12:47 PM
you will need the extended Ford add-on set.
F-350 08 XLT, Job 3, 5/22/08 build, Auto, CC Long Bed, 3.73's. Dark Stone Exterior, Medium Stone Interior. Line-X, Buckstop winch bumper, Snug Super Sport Canopy. 2 German Shorthaired Pointers riding shotgun.
Stroked & Stoked is offline
post #5 of 5 (permalink) Old 03-08-2006, 08:55 PM
klhansen's Avatar
My Photos: (180)
I have one that's dead on both banks, so it's not unheard of.
Like the other poster said, you'll need the Ford Enhanced package on AutoEnginuity to do the Injector Buzz test. A phonecall to Jay would get the add-on and the activation code for the enhanced setup. It may give you the P1316 code without the enhanced set, but not sure. P1316 just means you have codes stored in the IDM, but you need to do an on-demand test (like injector buzz) to get the codes out of it.
), AIS,
regulated return,
klhansen is offline
