Texaco oil - Diesel Forum - TheDieselStop.com
Old 12-01-2006, 05:53 PM   #1 (permalink)
Texaco oil
Normally use Rotella T but my mechanic swears by Texaco products. Let him use it last time. Truck now definitely louder and idle has very slight hunt. It's going to the recycling tank today and back to Rotella. Anyone have input on Texaco oil? Rich
02 F350 PSD 4x4 Reg. cab, auto, Gale Banks Transcommand, LineX, PopUp hitch
Drag: Custom DoubleD 2 horse gooseneck full living quarters
RichM is offline
Old 12-01-2006, 06:00 PM   #2 (permalink)
Re: Texaco oil
was the oil even rated for diesel use? Plain ol ordinary oil is subject to foaming, which the hpop and injectors do not get along with.
99.5 F350 SRW 7.3PSD 6SP CC 4x4
<span style="color: red"> autometer pro-comp pyro-n-boost, wicked wheel, Reg return, AIC mod, Exhaust brake mod </span>
banging on all 8 since 11/24/06
Tom
tlutman is offline
Old 12-01-2006, 06:02 PM   #3 (permalink)
Re: Texaco oil
yes it was diesel rated 15w-40. I looked at the container but slept since then
RichM is offline
Old 12-01-2006, 06:05 PM   #4 (permalink)
Re: Texaco oil
I'm sure Texaco produces fine lube oil, but it has been talked about, here in many threads, how picky the 6.0 can be about oil. Mine is not, but many have found one brand to be better than another for their particular truck.
2003 KR F-250 4X4 CC SWB, 6.0, 5 Speed Auto, 3.73 Axle, no Limited slip. Rhino bedliner, Unicover bed cover.
Built on February 19, '03
#2 93 F-150 XLT, 5 Liter, Auto, 4X4, X Cab. 251,000 miles. Uses no oil between changes.
montanafan is offline
Old 12-01-2006, 07:56 PM   #5 (permalink)
Re: Texaco oil
I used Texaco Ursa in my 97 PSD. I used it for about a year in my 2000 then switched to Rotella because my source for the Ursa went away.
444-4D is offline
Old 12-01-2006, 08:59 PM   #6 (permalink)
Banned
Re: Texaco oil
It could be that you got ahold of some of that new CJ-4 oil designed for the newer low emission diesels. That stuff came out about mid October. It would be called Texaco Ursa Premium TDX EC. It has considerably reduced SAPS (sulfated ash, phosphorus, sulfur). Don't know if that would cause your concerns or not.
Texaco is Chevron. We know Chevron Delo 400 oils are exceptionally good. Chevron's Texaco labeled oils can't be that much different, and may even be the same. The Texaco Ursa Super Plus and Extra Duty diesel oils don't come in a 15W-40 grade. So count them out. But Texaco's Ursa Premium TDX (non-EC) does come in 15W-40, and it is CI-4 rated for our older diesels. This is the only Texaco oil I would use. [img]/ubbthreads/images/graemlins/smile.gif[/img]
Gooch is offline
