Throwing lots of tranny fluid - Diesel Forum - TheDieselStop.com
Old 09-22-2009, 05:10 PM   #1 (permalink)
I have a 2001 F350 7.3. (Stock) Pulled in from camping trip yesterday and began to back the trailer (31ft) into the driveway. After that I noticed lots of transmission fluid on the street and driveway. This same thing happened to me about a year ago and mechanic said it was a seal in the torque converter. Something about the seal heating up, getting soft which allowed fluid to escape. Local dealership says this is a common thing with the 7.3 and called in "normal". Anyway, I had the seal changed. Well now this happens again. Any thoughts as to what the problem is?
Pulled same trailer 2 months ago on a very long trip with no problems???
kyle_tx is offline
Old 09-22-2009, 06:58 PM   #2 (permalink)
Mark Kovalsky's Avatar
It won't get hot on long trips. It's backing things up that get it really hot. There is an aftermarket seal that works a lot better than the stock seal.
A really good trans cooler will help. Replace the aux cooler with a cooler from a 6.0L truck. Keep the cooler in the radiator in the circuit.
Mark
Mark Kovalsky is offline
Old 09-22-2009, 09:32 PM   #3 (permalink)
Where would I get the aftermarket seal? Who makes it? Having never done this before...would I have to drop transmission or is it something that I could do here at the house?
kyle_tx is offline
Old 09-22-2009, 09:53 PM   #4 (permalink)
knoweigh's Avatar
yes, as stated,it's the backing up that's hard on our tranny's. I can pull 13k pounds all day down the highway, but toss it in reverse for just a few hundred feet without using low range, and I would suspect that front seal will definitely weep.
What I've been hearing preached for the past 5 years is, use low range (assuming 4x4 model) when backing any significant weight.
I ALWAYS use low range when backing anything over say 5000lbs, even on flat ground.
my $.02 worth.
y2k F250 7.3 psd Calif emissions, ext cab long bed 265/75/R16 E rated tires, 190k miles 4x4 (nv271 manual t-case) 7.3 #1247981 1/18/00 (forged rods), 3.73LSD, non-diode 4R100, Dp tuner stock, 60t 60e 80t 80e, high idle. DIY 6637 air filter, wicked wheel, turbo master WG controller, turbo lifesaver, bellowed uppies, 4" downpipe & exhaust, 203t-stat, triple pod glowshift gauges (egt, tranny, boost), Ride-rite 2330 air bags, BTS VB, Sports a Western plow when the white stuff flies.
Trailers:
I'm usually towing 1 of several trailers I've built.
15ft car hauler (1000lbs empty; 5500lbs loaded)
26ft deck over car hauler (2000lbs empty; 7k loaded)
36ft car hauler (Was tongue pull; have since converted into 5er'. 4500lbs empty; 14k loaded)
https://lh5.googleusercontent.com/-g...0/IMG_4130.JPG
knoweigh is offline
Old 09-22-2009, 10:45 PM   #5 (permalink)
Any trans supply house will have it. I don't remember who makes it.
The trans has to come out to change the seal.
Mark
Old 09-23-2009, 12:38 AM   #6 (permalink)
No mine is a 2wd. So the diagnosis is that I need a new front seal?
Another Question....I am about to start running back and forth to the deer lease with NO load. Do you think the seal would be a problem without a trailer in tow?
kyle_tx is offline
Old 09-23-2009, 05:58 AM   #7 (permalink)
You may not need a new seal. If you don't back up with a large load it probably isn't going to leak again. If you change the aux cooler for a 6.0L cooler it probably will stay cool enough to not leak when backing a large load.
Mark
Old 09-23-2009, 11:28 PM   #8 (permalink)
FleetMan's Avatar
As Mark said, you may not need a new seal. I was backing mine up a hill to park a travel trailer and dumped ATF all over the place. Definitely got my attention. I made sure the tranny was topped off correctly and drove it another 50,000 miles, many of them towing the TT with no problems. Then I had the BTS tranny installed. Even with additional cooling capacity, Tru Cool Max but no OTW cooler, I can see the tranny temps begin to rise if I have to do a lot of backing and maneuvering. If you do not yet have a transmission temperature gauge, I'd highly recommend you install one so you can monitor those temps.
Early 99 F250 PSD (XLE4) XLT, Extended Cab, Short Bed, 4X2, BTS Trans/TC, 3.73 Limited Slip, Transfer Flow 48 Gal. Mid-Ship Tank
Western WA - Member since August 2001
FleetMan is offline
Old 11-08-2009, 03:01 AM   #9 (permalink)
boomboom's Avatar
I had this problem multiple times until I put the 6.0 cooler in. If you start out with cooler tranny temps chances are it wont happen again too GET A TRANS GAUGE
boomboom is offline
Old 11-08-2009, 07:33 AM   #10 (permalink)
That's where the oil to water (OTW) cooler really shines. It would really help in those situations.
Mark
