Thump when brakes applied???? - Diesel Forum - TheDieselStop.com
Old 03-26-2005, 06:30 PM   #1 (permalink)
Just recently when i apply the brakes in makes a small thump and pulls to the left. anybody experince this before? Could it be a sticky caliper? Any ideas would help. thanks
Kevin
y2k f-350 4dr.4x4 shortbed. a couple of small things done here and there.
kevinfromkc is offline   Reply With Quote
Old 03-26-2005, 07:31 PM   #2 (permalink)
Re: Thump when brakes applied????
check your ball joints my truck is doing the same
2000 drw psd, 18k mod homemade tymer intake,dp tuner 40 hp ecu 255/85/16 truxus m/t
bansheetroy is offline   Reply With Quote
Old 03-26-2005, 09:35 PM   #3 (permalink)
I have the same symptoms.I suspect the sticky caliper also.Thump only happens when applying the brakes and will shift from front to rear whenever I apply the brakes.Only one thump and then it is gone,apply brakes one thump a little shake and a pull.
"Real Trucks Don't Have Spark Plugs"
2000 F250 Lariat Crew Cab, 4x4
A Few Mods To Make It Better than Stock
"The Smoke Don't Mean Its Broke!"
Bushwakd is offline   Reply With Quote
Old 03-26-2005, 11:49 PM   #4 (permalink)
I'm thinking Sway Bar on my 01!
mobeydick is offline   Reply With Quote
Old 03-27-2005, 02:20 AM   #5 (permalink)
On Both my 01 and my friends 00 F350 it was a ball joint.
2001 F250 Ext Cab, Long Bed,4x4, 6spd,AFE Stage II, Dual A-pillar boost and pyro.
Rodeofox is offline   Reply With Quote
Old 03-27-2005, 08:55 AM   #6 (permalink)
JimTJr's Avatar
My Photos: (20)
Ball Joint....mine did too.. ONE THUMP... thats it. Then if you accelerate or go a bit farther,,, then hit the brake again, thump/ or CLunk,,, whichever ya want to call it.Really when you go in to fix it/fix them.. replace all four...not alot more work,,and they all are close to being bad if one is probably.
Saves tearing it down again later.
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB. My pics! '03 Dually pics!, New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline   Reply With Quote
Old 03-27-2005, 09:46 AM   #7 (permalink)
I have that same "thump" when I apply my brakes. Same symptoms. I have checked my ball joints (greasable), and they are very tight and have no wear. Any follow ups or information on the caliper sticking would be helpful. I don't have any knoledge on brake units and diagnosing, but would like to find out how to check these things. Thanks, Bob
2001 F250 XLT 4x4 CC SB SRW (hypermax chip) Banks monster exhaust, Jasper transmission (ouch)
korg is offline   Reply With Quote
Old 03-27-2005, 09:58 AM   #8 (permalink)
Mine doesn't pull left or right and it "sounds" Feels like right under my feet!! Truck's in ther shop right now for other reasons!!
Old 03-27-2005, 10:18 AM   #9 (permalink)
Yep. Feels like its right underneath the floorboard. I'm getting that too. Let me know if you find anything out. Thanks, Bob
Old 03-28-2005, 09:45 PM   #10 (permalink)
I found mine. its the crossover bar that hooks to the pitman arm. i think i am going to have to replace the rod . doestn look likr that ball joint comes out. Doesnt look hard just alot of money for the part. everything else is tight.
kevindale is offline   Reply With Quote
Old 03-29-2005, 11:22 PM   #11 (permalink)
Think I"ll bump this back to the top as I have the same noise under my floorboard. All along I was thinking it was my Sway bar also but after reading this I'm checking balljoints and bar conneted to pitman.
(His)99.5 F250 XLT PSD CC LWB SRW Auto 4X4 Born on 1/25/99
K&N Air Filter,B&W Turnover ball, WD Turbo Chip, WD Gauges, Bilstein's, Walker BTM, 2002 Headlight upgrade,Timbrens
(Hers)02 F250 XLT PSD CC SWB SRW AUTO 4X4
JCARSON is offline   Reply With Quote
Old 03-31-2005, 10:44 AM   #12 (permalink)
I think that I have seen posts in the Excursion side that said the fix was taking out the drive shaft and greasing the the shafts that it slides onto. I was going to do it next chace I had. Also check the sway bar end link bushing 10-20 dollars and 30mins. I hear that it helps a lot to. On my truck it connect beneath the drivers feet.
Hope this help!
DZL_X_4x4
2000 Excursion Ltd PSD 4X4, ProComp 6" lift, (6) MX-6 Adj. shocks, dual shock hoops, ProComp traction bars, dual shock steering stabilizer, 35x12.5x17 ProComp Xterrains, 17x10 Welds Stonecrushers, SCMT 1705, AFE StageII PG-7, Hellwig Sway Bar, TV/VHS/PS2/DVD, Billet Grill, Chrome Brush Guard, ProComp Lights
dzl_x_4x4 is offline   Reply With Quote
