Time for a new turbo...suggestions? - Diesel Forum - TheDieselStop.com
Old 09-21-2007, 07:59 PM   #1 (permalink)
I am getting a ton of smoke and I have quite a bit of lateral movement in the turbo shaft, but not much endplay. I guess it's time for a replacement, but I wouldn't mind doing an upgrade at the same time. I'm on stock injectors so I'm not looking for a huge improvement, and I'm trying to stay as cheap as possible. What's the difference with a van turbo? Also, is it necessary to replace the pedestal at the same time? I've got 125,000 miles on the truck.
2000 F-350 CC/SB 4x4 Lariat. Skyjacker 8" lift, 38" Parnelli Jones Dirt Gripz. 4" turbo back exhaust, TS Performance 3 position chip.
scott6760 is offline
Old 09-21-2007, 09:00 PM   #2 (permalink)
Re: Time for a new turbo...suggestions?
It isn't necessary to replace the pedestal, but it is a nice piece to use. As for the turbo, I would recommend rebuilding your stocker. It sounds likke the turbine seal is not in good shape, along with the bearings. A rebuild kit is fairly cheap. As for the van turbo, it has a non wastegated 1.15 turbine housing, (larger than the stock .84) with a different trimmed turbine wheel. it is a nice turbo. If you can find one cheap, I would run it. Otherwise, rebuild yours, if you're on the cheap.
'03 F-250
'01 F-550
Boonman is offline
Old 09-21-2007, 10:50 PM   #3 (permalink)
boonman is right, if yu not lookinn for big hp stay with a stocker or rebuilt.
2002 f350 crew cab short box 3inch tuff country level kit 315 toyo mudd terrains on 8 inch nitto rims afe stage11 intake with pre filter window tint leer canopy auto meter quages . 4 inch mbrp exhaust. superchips 1805 tuner. towinn our 2004 27 ts komfort tt.
http://community.webshots.com/user/rws444psd
rws444psd is offline
Old 09-21-2007, 10:53 PM   #4 (permalink)
Gheck out the Garrett site
http://www.turbobygarrett.com/turbob...erstroke.html.
I upgraded to the GTP38R Turbo kit.
2001 Ford F350 Lariet 154,000 miles, CC, LB, 4X4, AUTO withstall and shift kit, 6 Stage custom Bullydog Chip. Garrett Ball baring turbo, 100 hp injectors, full magnaflow exhaust w/ 5.5 in tip. Aftermarket air intake. Full gages.
http://community.webshots.com/user/m...host=community
68 Bronco half cab,289,3 on tree uncut and restored
71 Bronco moded,302,double stick, mod 3 speed under restoration
76 Bronco almost restored with everything stainless thats possible,302,PS,PB,disk,
MarkSeve is offline
Old 09-22-2007, 01:17 AM   #5 (permalink)
BVA
Or send it to Ron's Turbo in Utah, for $310 he will completely rebuild your stock one. For $150 he will sell you the non EBV Pedestal and the appropriate outlet housing that actually has a little better flow. For another $70, he will install the Banks wheel which is like the Wicked wheel, and will elliminate surge under load, and he said helps the turbo spool a bit faster.
The total for me was $550 with shipping, and I just got it back yesterday, and am installing it tomorrow. Best way to find him is to look for him on Ebay, search for powerstroke turbo, and his number is on there, he has an excellent reputation.
I also thought of going with Turbonetics or Garret Ball Bearing turbos, but the end result was really no extra hp, unless you add fuel system mods, which is a big step up in $$$.
Good luck...
2000 F250SD 4x4 Crew Cab, 4" MBRP, AFE Stage 2, Rebuilt Stock Turbo, Banks wheel, DI Regulated Return, 6.0L Intercooler, FASS 150, Fuel Tank Mod, Edge Evolution 2, with DP Tuner 40T, 80E, and 120R tunes, Boost Annihilator. 3" lift, 20" XD Hoss w/35" Nitto Mud Grapplers.
BVA is offline
Old 09-22-2007, 01:57 AM   #6 (permalink)
I have had Ron rebuild several turbos for me as well. He does excellent work.
2003 7.3 PSD, TERMINATOR HPOS, DP LIVE TUNED, ITP Reg. Return, Spearco, DI up-pipes, PI coverter & TransGo tugger, AFE-II, 4" MBRP, Duramax fuel cooler, 20K on the clock
JMS1 is offline
