Torque Converter Lock-Up questions (again, sort of) - Diesel Forum - TheDieselStop.com
Old 08-08-2005, 12:55 AM   #1 (permalink)
I know tranny and t/c ?'s pop up here alot, I read 'em, search for them and study them but I am still left with questions. I posted awhile back about my 2-3 shift which seemed like it was shifting twice. First a 200rpm drop...5 sec. pause....then the rest of the shift into 3rd approx 400rpm drop. I changed the fluid/filter, added the sonnax/tri....no help. I bought the t/c lockup led but talked myself out of installing it.
Now, I have added a 40hp tow tune from Jody [img]/ubbthreads/images/graemlins/grin.gif[/img] (he and his tune are awesome [img]/ubbthreads/images/graemlins/smokin.gif[/img]). The shift schedule has completely changed but I still have the double shift into 3rd. And, like others have posted in the past, my 1-2 shift is firm, 2-3 harsh and 3-4 very harsh. The harshness changes with the way I accelerate.
Is it possible that I am seeing the t/c lockup and then the shift into 3rd (or vice versa)?
I have no unusual noises, and do not recognize any slippage. I am very concerned [img]/ubbthreads/images/graemlins/eek.gif[/img] that I am seeing 4 shifts instead of 3 and the harshness of the shifts.
Thanks guys for any help....
99 F350PSD SRW, (1-98 build) Lariat. crew cab, Black/Tan
Napa Gold air/fuel/oil filters. Amsoil Torque drive ATF, Max Flow cooler, Sonnax
2004 27' Sunnybrook TT 7000 lbs
8animals is offline
Old 08-08-2005, 06:26 AM   #2 (permalink)
haul_n_horses2's Avatar
My Photos: (17)
Re: Torque Converter Lock-Up questions (again, sort of)
One of your "double" shifts is the TC lockup and the other is a change in gears. I would not worry. I would contact Jody about the shifting if it is changing the way you drive.
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2µ Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203º T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
haul_n_horses2 is offline
Old 08-08-2005, 11:16 AM   #3 (permalink)
SmokeyWren's Avatar
My Photos: (44)
If it happens at around 40 MPH, yes. Or if Jody changed the torque converter lockup strategy, then you'll have to ask him at what speed or RPM the torque convertor should lock up.
If you have a digital tach - such as the Ford auxiliary idle controller (AIC) - then you can easily tell the difference in the TC lockup and a tranny shift. With a warmed up tranny, the TC lockup drops engine RPM by about 200 at about 37 MPH, but a tranny shift will drop engine RPM 400 to 600 or more, depending on throttle position.
SmokeyWren is offline
Old 08-08-2005, 03:33 PM   #4 (permalink)
My Photos: (22)
You may need to change to the updated Orange color capped Solenoid pack in your tranny to fix this issue. There is a TSB out about it, but I don't have a link for it.
Hammer
Check out what I recently bought:
2002 Quicksilver Z06 Corvette
I still have the:
2001 F250 Lariat CC/SB 4x4 7.3 auto
TERMINATOR HPOS...Ceramic coated Garrett GTP-38R with BBHA & GDS outlet...DP-tuner Big Oil Program...ITPdiesel Fueling and overboost regulator...6.0 CAC...AFE Stage-II PG7... Magnaflow 3.5dp/4exh...5R110 TC, BTS VB, John Wood pump mods, & V10 cooler...Schaeffer's 9000 5w-40...Oilguard bypass...and other stuff
On the shelf collecting Dust: <font color="green"> Stainless Grill Overlay </font>
<font color="red"> Carolina PSD club </font>
Get Your Tuning Here: www.DP-tuner.com and your Fuel kits here: www.ITPdiesel.com
TheHammer69 is offline
Old 08-08-2005, 03:35 PM   #5 (permalink)
weitekampt's Avatar
Good luck bocat, I am following this question. I had similar problems but I really think Jody's tune fixed the problem in mine. I do have the orange packs in mine. Hammer told me to double check that when I had the pan down. Made me fell a bit better. But good luck!
*2002 Crew Cab SB 4X4, XLT Lariat, BTS Trans, 6.0 cooler, DP Tuner F-6 Stock, 60T, 80T 80E, AutoMeter gauges, AIH delete, AIS, Zoodad, HX Crossover, 203 stat, Coolant filter kit, Rotella ELC, 15W40 CenPeCo, Terra Grappler 285/70/17, Monroe Reflex shocks, intercooler wrap removed, Roll-n-Lock, Recon cab lights, 212,000, DrawTite brake controller, AIC module, Straight Pipe,
weitekampt is offline
Old 08-08-2005, 03:50 PM   #6 (permalink)
My Photos: (22)
I almost forgot another thing besides the orange solenoids. It doesn't hurt to check the torque of the nuts and bolts of all the other valve bodies and solenoid pack. There was a guy who was having similar issues a while back and all he did was loosen and re-torque all the solenoid fasteners and his flare was fixed. When I installed my BTS valve body, I decided to torque check all the other nuts and bolts and discovered three that were significantly lose.
Hammer
I still have the:
Old 08-08-2005, 05:15 PM   #7 (permalink)
I am not familiar with the orange capped solenoid pack and did not notice anything like that while putting the sonnax mod in but I did check the torque of all the valvle bodies and they where all good. I also saw a post recemmending to check those. If anyone has more info on the orange capped solenoid pack I would like to see it. I am really starting to think that I am worrying about nothing and that the 'extra shift' is just the t/c locking up. I am going to try to get an analyzer to plug in and see if that is what it is, I will post results.
Again, I appreciate the support!
8animals is offline
Old 08-08-2005, 05:23 PM   #8 (permalink)
i have the same thing. i have a early 99 with jody's pmt1 and 40hp tune. when i am at half throttle or less the t/c locks during the shift to third. it loses a lot of rmp and my truck kinda falls flat. if i am towing or over half throttle it does not lock untill after the shift to 3rd and works good [img]/ubbthreads/images/graemlins/shrug.gif[/img]
99 f250 (5/98)ais, pre pump/in tank, zoodad, walker BTM. dp-tuner chip.
eddyzima is offline
Old 08-08-2005, 09:29 PM   #9 (permalink)
weitekampt's Avatar
You know what, maybe that is my problem. [img]/ubbthreads/images/graemlins/blush.gif[/img] I did recheck the torque like Hammer said and did notice that some of them were loose. But there were some that would "snap" from sitting and then allow you to snug them up. Not a very good practice when torquing, but I was in a real hurry to get the project done. Stupid me! [img]/ubbthreads/images/graemlins/crazy.gif[/img] Maybe I should loosen them and do it accurately like this other person did. When you are dealing with 85 inch/lb....a little "snap" would probably be 10 or more lbs. Never thought about that. THANKS Hammer!
Old 08-08-2005, 10:43 PM   #10 (permalink)
My Photos: (22)
The older solenoid packs have green caps if I remember correctly. I'm pretty sure that is what would be in your 99. I am not sure what time that Ford made the switch to the orange. I have a Ford Reman in my truck and have no idea when the reman was installed. It has the Orange caps and don't know if they were on all 2001's or if it was an upgrade when my tranny was replaced with a reman.
Hammer
I still have the:
