Torque Converter Won't lock - Diesel Forum - TheDieselStop.com
Old 02-23-2010, 11:23 AM   #1 (permalink)
bigdogal's Avatar
My Photos: (6)
No Torque Converter lock-up
I've had my 1999 for about six years. It has a monsterbox tranny with a BD torqloc that has been fine until the other day. Suddenly, the torque convertor won't lock up. I removed the torqloc and reconnected the wires that control the convertor lock up and still nothing. The PCM must be throwing a code cause now the OD light is blinking. Any ideas? Everything else works fine and shifts fine.
99 F250 Superduty Extended Cab 4x4 7.3, 6" lift, Dieselsite 6-pos chip, Autometer Gauges, Banks Six gun, Monsterbox 4R100 trans, 4" exhaust with twin 5" stacks, AFE Stage 2 intake, Banks Intercooler, Hypermax H2E Turbo, 203 Thermostat, FASS 85/150 Fuel System, Snow water/meth Injection, Fluiddamper, ZEX Nitrous, Evans Waterless cooling, B&D Torque Loc, Decelerator exhaust brake
bigdogal is offline   Reply With Quote
Old 02-23-2010, 09:44 PM   #2 (permalink)
Will your exhaust brake lock the torque converter?
Wayne B
2000 F-250 Super Duty 4x4, Auto, Super Cab, Long Bed.
http://tinyurl.com/nguxnv
My other vehicle:
Piaggio MP3 500
WayneB is offline   Reply With Quote
Old 02-23-2010, 09:58 PM   #3 (permalink)
bigdogal's Avatar
My Photos: (6)
My exhaust brake is not connected to the Torqloc. I'm going to pull the codes and check the converter by manually grounding the lockup wire and see where I am.
Old 02-24-2010, 05:13 PM   #4 (permalink)
bigdogal's Avatar
My Photos: (6)
Solved
My 3rd brake light was out!!!! Everything works fine now thanks to an older post I found.
Old 02-26-2010, 08:00 PM   #5 (permalink)
bigdogal's Avatar
My Photos: (6)
My 99 F250 4R100 4x4 torque converter suddenly is failing to lock. I checked the brakes light bulbs, all are okay. I pulled two codes off the truck, P0743 Torque Converter Clutch soleniod circuit electrical and P0741, Torque Converter Clutch solenoid circuit performance or stuck off. Also, no engagement when I ground out the TCC wire. Any suggestions before I open the bottom up? It's looking like the TCC solenoid to me.
Old 02-28-2010, 08:03 PM   #6 (permalink)
Mark Kovalsky's Avatar
It's either the solenoid or the wiring to the solenoid. Those codes don't isolate the problem to either one, you'll need to do some electrical continuity testing to know what to replace.
Mark
Mark Kovalsky is offline   Reply With Quote
Old 03-03-2010, 01:25 PM   #7 (permalink)
bigdogal's Avatar
My Photos: (6)
Thanks Mark.
Old 03-03-2010, 01:26 PM   #8 (permalink)
bigdogal's Avatar
My Photos: (6)
Not Solved
While the third brake light was out, I still have no lock up. No lock up when ground out TCC control wire. I pulled two codes off the truck, P0743 Torque Converter Clutch soleniod circuit electrical and P0741, Torque Converter Clutch solenoid circuit performance or stuck off.
Old 03-03-2010, 02:12 PM   #9 (permalink)
That still applies.
Mark
Old 06-01-2011, 06:23 PM   #10 (permalink)
Did you ever figure out the problem? I have an 2002 expedition with the 5.4..shift great just wont go into lockup..any ideas? lockup solenoid on a 4r100 is located on the whole solenoid block..rebuilt @100 on ebay..ford wholesale@295..have checked wires..no burnt or bad places in it..no idea which wire to check for solenoid power
national is offline   Reply With Quote
