Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 7.3L Power Stroke Engine and Drivetrain
7.3L Power Stroke Engine and Drivetrain Discussion of the 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 03-07-2005, 08:04 PM   #1 (permalink)
Tranny cooler question
Tomorrow I'll be receiving my Factory Tech Valve Body, and either tomorrow afternoon or Wed morning I'll be installing it, and doing a tranny flush and change to Mobil 1. On the FAQ, it says to remove the cooler return line and clamp the tubing over it. I just want to make 100% sure I've got the right line...it's the rear metal line(on the passenger side) that then joins up with another line just like it that attaches to the front of the tranny, correct? By joins up, I mean they are just routed side by side - not join to become 1 line. This is the line I need to drain until air starts coming out, then shut the engine off - right?
BTW, just a quick note...I ordered the FTVB(as well as a few other things) from Bob at Dieselsite, but he was out of the valves. I found this out on Saturday(I placed the order on Thurs night). When he told me he was out, and that Gregg would be shipping them directly to customers, I told him I was leaving on a trip(with the truck) on Friday morning. Long story short, he had Gregg overnight it(at their expense, not mine) to me so that I'll have it tomorrow and can get everything sqaured away before the trip. Can't beat customer service like that! Thanks Bob!
Mike
2002 F250 SC SB 4x4 7.3L 3.73LS and 4R100. FTVB, Amsoil all around except tranny/transfer case, which are Mobile1, MBRP 4" turbo back, ISSPro gauges, AIS intake, quasi-zoodad mod, in tank and pre pump fuel mods, harpoon mod, Line-X bed liner, Retrax bed cover. Chip coming soon!
Aviatrr is offline
Old 03-07-2005, 08:53 PM   #2 (permalink)
GEM
My Photos: (10)
Re: Tranny cooler question
Aviatrr,
Yes, you have the right line. The one at the BACK of the tranny is the return from the coolers.
Your experience with Bob Riley and Gregg Evans is typical [img]/ubbthreads/images/graemlins/smile.gif[/img] I've done business with both and my experience matches yours.
GEM
'01 F250 7.3L PSD 4x4 XLT SD SC SWB Harvest Gold, PMT1(stock)/Tipton 4-pos chip(PMT1), Factory Tech Monster Box, Dieselsite trans filter, Tru-Cool, 3.73 LS, camper/offroad/tow, chrome steps, cab clearance lights, Lund deflector, bedliner, Pro Flaps, Warn 9500# front/rear receiver mounted winch, Tekonsha brake controller, 285/75R16 Yokohama Geolander AT+II's, A-pillar w/ISSPRO EV gauges, ISSPRO Turbo Temp monitor, "Hutch" fuel mods, 'Pooned tank, Airdog, open element intake w/Zoodad, ATS housing, CCV reroute, ITP H/X, JNB reg fuel return and supply w/no CVs & restrictors, AD#8, TC lock, power pedal, manual idle, coolant filter, DPPI T409 exhaust w/3.5" DP, Aeroturbine, Tuff Country 2.5" leveling kit & 4" rear blocks <font color="red">www.gmayle.com</font>
<font color="blue"> Colorado Powerstroke Club </font>
GEM is offline
Old 03-07-2005, 08:54 PM   #3 (permalink)
Right, and right.
Casey_1 is offline
Old 03-07-2005, 09:04 PM   #4 (permalink)
fordmastertech's Avatar
Just make sure the transmission is up to temperature or you will have a BIG MESS.
Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
Old 03-07-2005, 10:27 PM   #5 (permalink)
Ok...why, exactly, would it be a big mess? I'll definitely make sure I go out and drive it for 15-20 miles before I start the job....but, I can't figure out exactly why it would be a mess if I didn't? Is the problem prevalent in cold climates, or any?
Mike
Aviatrr is offline
Old 03-07-2005, 11:01 PM   #6 (permalink)
The 4R100 transmission has a external fluid bypass for cold operation on the side of the transmission where the cooler lines attach. When the transmission is cold no fluid goes through the cooler lines or coolers ,it's bypassed. When you remove the line and run it cold it will shoot out of the rear port and by the time you notice it you will have many quarts of fluid on the ground and none in your recovery bucket. It can happen in any climate areas. Hope this makes sense.
FMT
Excursion Pics
Old 03-08-2005, 12:08 AM   #7 (permalink)
make sure you have the right size line also. mine took an inside diameter of 3/8, I bought a bigger one originally and had to walk to the store to get a smaller one in the middle of the process, what a mess that made [img]/ubbthreads/images/graemlins/phoney.gif[/img]
edit: I ordered my valve and tranny cooler from him last week also. shoud be here on wed. guess I should have waited to flush my tranny, but I just had to work on my truck this weekend [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
02 F250 PSD CC SB 4x4 Auto Tranny, AIS intake, ISSPRO guages, MBRP 4" T304
Towing an 05 Sprinter 294FWDB 5th wheel
hhills is offline
Old 03-08-2005, 09:44 AM   #8 (permalink)
SmokeyWren's Avatar
My Photos: (43)
What FordMasterTech said. Remember where you wrote: "it's the rear metal line(on the passenger side) that then joins up with another line just like it that attaches to the front of the tranny, correct?"
That "other line just like" it is the bypass line. The bypass valve is on the front of the tranny, where that bypass line connects to the tranny in the same place as the cooler hot line. The connection on both ends of the bypass line is called a "banjo" connection - where two lines are connected together and become one.
When the ATF is cold, the bypass valve sends it right back into the back of the tranny instead of to the coolers. When it tries to go back into the tranny, you have it disconnected right there, so the cold bypassed ATF squirts out onto the driveway instead of turning the corner and going back into the tranny.
Tecnhically, the bypass valve works on pressure, not temp. But the effect is that hot ATF goes to the coolers and cold ATF bypasses the coolers and goes right back into the rear of the tranny. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
My Sierra Blanca is a '99.5 PSD CrewCab hot-rod Towing Machine! BTS tranny; Ford Severe Duty Air Induction System (AIS); 4" stainless turbo-back exhaust; DP-Tuner tunes flashed into an Edge Evolution tuner; ISSPRO EV gauges and Turbo Temp Monitor (TTM); Auxiliary Idle Controller (AIC); SP-Diesel exhaust brake and torque converter controller. Top Job front end replacement. I special-ordered it new and plan to drive it until it quits.
SmokeyWren is offline
Old 03-08-2005, 10:18 AM   #9 (permalink)
Almost but not exactly correct. You are correct about the mess but there is still fluid going to the cooler when cold. The colder fluid doesn't flow as easily so there is more volume being pushed thru the bypass valve. This is the same principle as the oil pump relief valve in your engine. Does the oil bypass the engine bearings and go straight back to the oil pan when it is cold?
444-4D is offline
