whats the best oil for the tranny? how much does it take? whats the procedure? also whats the best oil for the diff's front and rear? how much do they take?
2000 f 250 4x4. ccsb
just hit 206,000
38R with Turbo Master
5 inch miter cut stack
remote start.
Autometer C2 series gauges.
5.5 inch lift with blocks and shackle drops
DIESELSITE HEAVYDUTY BOOTS ALL AROUND.
ITP in tank kit-awesome! frame mounted pre-filter
20 in diamo rims-33in toyo A/T
DP-TUNER F6- no start,stock,60 tow codes, 80E codes, 120 race codes
DIY TYMAR with donaldson filter.
AIH cut off
hood insulation removed
always bright overhead display
05 style headlights with 14k HID'S
08 leather front seats
bypass oil system
running on WMO!
DIESEL SITE coolant filtration
Denso HT gear reduction starter. Soo fast!!!
Wish List..... BTS....Stage 3 hybrids.... Push rods and Spings!!
someone else will chime in with the specs, i just did the diff and got some good advice here, its a few pages back, thread is titled "which rear diff fluid to use" or something.
my one bit of advice is make sure you have a pump to get the fluid into the pumpkin, the fill hole is in the absolute worst place ever
The rear diff requires 75w140 synthetic diff lube. All the synthetic oil folks make it, including RedLine, Royal Purple, Amsoil, and Mobil 1. The Ford dealer has it in a Motorcraft wrapper for around $20 per quart. I bought the house brand at Wal-Mart, SuperTech or some such, for around $10 per quart. Good stuff.
The front diff requires SAE 90 or 80w-90 "premium" diff lube. I'm pretty sure that "premium" means synthetic. Your Owner's Guide probably says 75w90 but that has changed since that guide was printed.
Almost four quarts for the rear diff. For the front axle, it depends. Almost two quarts for the Dana 50 front axle, or almost 3 quarts for the Dana 60.
ok thanks. so do u have to pull the diff covers to drain them?
just hit 206,000
remote start.
AIH cut off
bypass oil system
running on WMO!
