Transfer Case Question - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 02-04-2008, 05:32 PM Thread Starter
99 ford f350...For some reason my transfer case shifter wouldnt stay in the two wheel drive setting and would occasionly try to engage the four wheel drive setting. But the shifter would get stuck in between while i was driving and be grinding the whole time. While i usually noticed it pretty quickly i didnt always catch it soon enough and know some damage has been done. Now when i engage the four wheel drive it just grinds most of the time and some times catches for intermittent four wheel drive. Does the whole thing need rebuilt or just a particular part/parts. And what are my costs looking like. Any advice would be greatly appreciated
acol19 is offline
post #2 of 4 (permalink) Old 02-06-2008, 01:54 AM Thread Starter
any help...please
acol19 is offline
post #3 of 4 (permalink) Old 02-06-2008, 02:04 AM
westvandude's Avatar
Not sure which one is in your truck... mine is an NP 273 F. Do a search for NP273 or whatever yours is. Tag should be on the back side of it halfway between rear and front driveshafts. I saw NP273 at around $695 rebuilt. You can get rebuild kit and do it yourself but not sure on those.
2001 F250 4x4 crew lariat 7.3L auto, DP Tuner F5 no-start/valet/20tow/80econo/140aggressive, NAPC 450series trans w/billet triple disc TC, ISSPRO egt/boost/pyro, foil delete, 6" stainless tip, Magnaflow 17979 4" turbo-back, dieselsite boots & coolant filter kit, HX crossover, boost fooler, 6.0L trans cooler, ported turbo housing, DIY 6637 Tymar, billet grill, line-x bedliner, tint, 08' alum diff cover, clear corners & tails, 20w LED taillight bulbs, cheap OPT7 HID kit, 2000w inverter, Tekonsha Primus brake controller, 220A HD alternator, 120w LED light bar up front, 2x18w led spots backup lights, 145USgal tidy tank, superlift 4" kit full springs & bilstein 5125 shocks, Level8 striker 16x8.5 blk rims, etc.
2009 VW Jetta 2.0TDI 6spd Highline full load except nav. 19" Audi RS6 rims. REVO tuned. Aftermarket android 4.2 navi 7" touch head unit, Custom fiberglass box MD Sound 12" & Boss NXD5500 amp. GTI grille and projector fogs.
BioPro190 owner. 20,000L produced 2010-2015.
westvandude is offline
post #4 of 4 (permalink) Old 02-06-2008, 08:26 AM
I rebuilt mine, it actually was pertty simple to do, depends on how mechanically inclined you are. you might check with your local Transmission shop and see if they got a used on in that's good they might let it go cheep... or rebuild yours. i also got my parts from the transmission shop, parts were cheep
2016 F-3506.7 PSD, Crew Cab, Long bed, Lariat with the Ultimate package, Fx4, Bench seat in the front, tan interior, white platinum with Caribou accent 5th wheel prep package, 3.55 rear end with Electronic lockers - Purchased New
2002 F-350 Crew Cab Long Bed, Lariat, 4x4, Automatic, , In-Tank Hutch Mod, Edge Insight Monitor. 320k miles
2000. Stock F-350 XLT 330K+ miles, white, 4x4, 6 spd manual, extended cab, Long Bed. Marinco Block Heater Mod, Tymar Intake. 4" Turbo Back Straight pipe, In-Tank Hutch Mod, Swamps Diesel 175/146 injectors - with TS Performance 6 position chip
jchipper is offline
