I was just about to change out the fluid in my 2001 F350 PSD's transfer case, and fluid poured from the fill hole. I live in a subdivision and didn't want to booger up the street if it leaked so I was going to use my Pella oil extractor. When I cracked open the filler, a huge stream of ATF came out.
Here's the questions. Is the filler hole approx. 4" above the drain on the rear side of the case? Secondly if so how could they over fill it, so that it poured?
Have you been loosing any fluid from the transmission that you can't figure out where it's going? Sounds like the input seal on the transfer case is allowing fluid from the transmission to enter the transfer case. I see this quite a bit on all sorts of 4x4 vehicles.
FM
__________________ Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
4" above sounds about right....and about the same distance to the right(as looking at it from the rear facing forward).
Sure you were on level ground when you checked it? If so, maybe it was filled while it was not on level ground. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Mike
Edit: Well, there ya go...FMT gave you a better idea what it could be than I did....and I learned something new! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
2002 F250 SC SB 4x4 7.3L 3.73LS and 4R100. FTVB, Amsoil all around except tranny/transfer case, which are Mobile1, MBRP 4" turbo back, ISSPro gauges, AIS intake, quasi-zoodad mod, in tank and pre pump fuel mods, harpoon mod, Line-X bed liner, Retrax bed cover. Chip coming soon!
Well I just bought the truck last week. The tranny fliud looks nasty, but the transfer case look almost brand new. When I cracked the filler open it spewed like a drain plug would. Hmmmm I might have to take a look at the seal.
The street in front of my home is perfectly level.
Sounds like previous owner filled the transfer case on a hill. [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img]
2002 F-250 XLT,6 Spd,AIS Intake,Air Horns (Hadley Twins),Quadzilla Stealth Module,Oilguard Filter,Starter Security Modification,XM Radio,Autometer Cobalt Gauges,Baldwin Coolant Filter,Edelbrock Shocks,Hellwig Sway Bar (Rear),Fabtech Dual Stabilizer,Custom Running Board Lights,Light of Fire Rear Lights,Diamond Plate Tool Box, Tailgate and Side Rails, AirDog Fuel Seporator with Isolation Mounts, Manual Trans Filter, HX Mod, Maxed out Credit Card. Born in Kentucky, Raised and Modified in New Jersey, Home of "T"
