Transmission - Diesel Forum - TheDieselStop.com
Old 11-10-2012, 09:14 PM   #1 (permalink)
Question Transmission
I have a 2001 f250 power stroke with 233000 miles. I have changed the trans fluid at every 50,000 miles. This trans just quit going forward out of the clear blue. When it would go forward it went through the gears perfect, if you put it in park with the engine running after a few minutes it won't move forward but backs up great. Sent it to the shop they said it was the converter. So they changed the converter and pump. Now it is worse it starts off and then after about 2feet it drops out of gear. If you give it WOT it will slip and start moving then it will go through the gears. On the way home it would down shift just going over an overpass on the interstate. Any ideas?
Thanks. Rick
Rick79400 is offline   Reply With Quote
Old 11-10-2012, 09:21 PM   #2 (permalink)
RT
RT's Avatar
I'm not a tranny guru, but I think the phrase is, "stick a fork in it- it's done."
A BTS or a Ford HD would be good options.
Sent from my iPhone using Autoguide.com App
"IF YOU CAN'T FIX IT WITH A HAMMER, YOU’VE GOT AN ELECTRICAL PROBLEM"
RT is offline   Reply With Quote
Old 11-10-2012, 10:22 PM   #3 (permalink)
Mark Kovalsky's Avatar
The shop didn't know what they were doing. If it were the converter it wouldn't back up or go forward. Stick a fork in it - it's done. It isn't electrical, it isn't the converter, and it isn't some adjustment. It has had a mechanical failure that will require a rebuild or replacement.
Mark
Mark Kovalsky is offline   Reply With Quote
Old 11-14-2012, 10:44 AM   #4 (permalink)
As the other have said "stick a fork in it" my tranny did the same thing, one minute is was fine then the next it would barely move forward but reverse was fine, new tranny had to go in. I'd get my money back on the parts that where already changed because they where not the fit.
2000 SD CC 7.3L(stock) w/ 4" Dynomax exhuast system, Jasper HD tranny.
Diesel Manor ISSPRO EGT/Tranny Gauge kit
hansel is offline   Reply With Quote
Old 11-14-2012, 04:31 PM   #5 (permalink)
69mach1377's Avatar
233k? Pretty good there...
2000 F250 XLT 4x4 SC 7.3 w/Auto Tranny w/ TC L/U Sw & shift kit, Fully gaged, Cold air intake mods beyond zoodad, Stacked tuners, 4" Exhaust w/dual 3.5" outlets, 295/75/16 BFG ATs on 8" rims, 08 AlumDiffCvr, Bilsteins, otherwise mostly stock.
24' 5th wheel camping trailer, no RV parks...just the woods.
69mach1377 is offline   Reply With Quote
