Transmission broken - Diesel Forum - TheDieselStop.com
Old 06-28-2005, 10:30 PM   #1 (permalink)
JP4
Transmission broken
My 2003 transmission has reverse but no foward drive,
It only has 36225 miles on it and has never pulled anything large that a 14 foot motorcycle trailer.
Does anyone have a clue as to what is broken ?
The fluid level is ok and does not smell burner.
The only thing I have noticed lately is that the trans temp has been running around 180 running empty which is higher than it normaly runs.
Dave
2003 F250 4x4 crew cab 7.3 Green
1974 F250 "camper special" 2wd 390 4bl Green
JP4 is offline
Old 06-28-2005, 10:59 PM   #2 (permalink)
Pappy19's Avatar
My Photos: (6)
Re: Transmission broken
If I were you, I would check out the tranny shifter solenoid and the pedal assembly. The shifter solenoid is on the outside of the tranny on the driver's side and has been known to go bad and do wierd things to the tranny shifting. A bad pedal assembly can do the same thing. Both are around $100 each and take about 10 minutes to change out. The '02's were very bad for these 2 items going out and many have thought they had lost their tranny's only to find out later that it was these two items that were bad. Too late, they had already spent $4,000 on new tranny and TC.
2002 F-350 SRW Lariat,4X4, PSD with too many goodies to list. 182k and a very strong 7.3. SOLD
2008 F-250, SC Lariat, 4X4,Shortbed, Pueblo Gold/black, V-10, 4.10, auto, Delivered on 9/7/07, great looking rig. South Texas bumpers front/rear, Air Raid Intake System, Diablosport Predator, Magnaflow, Husky's, JJ's, Ford alarm/remote start, Marathon seat covers, Sirius, PIAA, Access cover, Weatherguard tool box, Rhino liner, Michelins, Duraflap mud flaps, Escort 9500i, MagHytec rear dif cover.
2007 Lincoln LT (wifer's grocery getter),Superchip,Magnaflow duels, K&N dropin, Leer Browning Special
1996 Ford Bronco EB; almost stock
2007 Kubota 900 RTV diesel with goodies.
pappy's truck
Pappy19 is offline
Old 06-28-2005, 11:23 PM   #3 (permalink)
Will it move in Manual 1 and 2?? If you have no forward movement in any ranges, I would recommend air testing the forward clutch and checking seperator gaskets for tears. If you get forward in Manual 1 and 2, try shifting to drive after manual shifting from Manual 1, 2, into drive. If you get 3 and 4 after manual shifting, most likely have a bad low 1-way clutch. Electrical components will not cause a no engagement concern.
djshum is offline
Old 06-28-2005, 11:32 PM   #4 (permalink)
JP4
Will it move in Manual 1 and 2?? If you have no forward movement in any ranges, I would recommend air testing the forward clutch and checking seperator gaskets for tears. If you get forward in Manual 1 and 2, try shifting to drive after manual shifting from Manual 1, 2, into drive. If you get 3 and 4 after manual shifting, most likely have a bad low 1-way clutch. Electrical components will not cause a no engagement concern. [/quot
Foward in manual 1 or 2 is very very slugish. If I rev the motor at all it wont move. But if I start our real slow and let it build speed and the transmission shifts to 3 Im on my way.
Guess the Transmission has to come out to put in the oneway clutch.
JP4 is offline
Old 06-28-2005, 11:47 PM   #5 (permalink)
If it is sluggish in man 1 and 2, I'm guessing your gonna need more than a 1-way. The pcm commands higher pressure in man 1 and 2. If it feels sluggish, most likely the forward clutch plates are burnt or you have a torn seal. The higher pressures in man 1 and 2 are enough to clamp the forward clutch to get movement, but not enough to hold when you accell. Drop you pan and see what it looks like.
djshum is offline
Old 06-29-2005, 08:34 AM   #6 (permalink)
JimTJr's Avatar
My Photos: (20)
If your on the western end of TN. then you dont have far to go to see BRIAN, At BTS. He will make ALL YOUR TRANNY Problems go away.... [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB. My pics! '03 Dually pics!, New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
