Transmission problem - Diesel Forum - TheDieselStop.com
Old 03-07-2005, 04:38 PM   #1 (permalink)
A friend was out 4 wheeling, got stuck and had to really get on it to get out. Now the truck will not shift into 3rd gear. The codes it threw were P0603, P0470, and P1728 and the OD light was blinking. After reading the codes and clearing them, we drove it around the block and the OD light didn't blink, but it threw the P0470 again. It is a 97 PSD with auto trans.
Any suggestions?
Thanks!
99.5 F250 Super Duty PSD SB Auto Trans; 4" Exhaust; Autometer guages on 3 pillar pod; SCMT; Oil Guard Bypass Oil Filter; Bypass Coolant Filter; ELC; 203* T-Stat/Billet Housing; ; Wicked Wheel; RAM Air mod, TC Lock up mod; DIY air intake (6637); Harpooned Tank; Pre-Pump fuel line mod;AirDog Fuel Preparator; HP Crossover; FUMOTO valve; BTS Valve body; Bilstein shocks; Centramatics; 285/75/16 GYW Silent Armor; SE Kong II horns; Viair 380 Compressor; 5 gallon air tank; Warn 9.5ti winch w/Amsteel rope on receiver mount, wired front and rear; Torklift tie downs; Air Lift SD air bags; Q logic with 12" sub; Complete Dynamat; Ford AIC wired thru Remote Start
live2fly172 is offline
Old 03-07-2005, 10:12 PM   #2 (permalink)
Re: Transmission problem
Any suggestions?
Thanks!
The 603 is a kam error, probably just something glitched when testing. The 1728 is a transmission slip code... The 0470 I cant seem to convert for the 97. The 1728 leads me to believe that you definitely put some strain on trans. You need to check your fluid and make sure you haven't burnt it. I would change your fluid and filter and make sure you drain your torque converter and change it also. Like stated I couldn't cross the 470 so I don't know what that is but, if fluid and filter fix it you'll be lucky...
2000 f350 xlt,drw,cc,2wd,7.3ps,4.10 ls,automatic,dp tuner flip chip,homemade tymar,4" turboback stainless exhaust, autometer gauges, custom overhead console,fold-a-cover,viper groundeffects,custom billet grille, lund windshield visor,vent visor,tinted windows,2dropped rear,custom mudflaps,line-x,asmoil thoughout,asmoil bypass filters, 29" Hadleys,onboard air,husky 16k ubs 5ver hitch, and pulling a 2005 32.5v Citation 5ver
chesapeakecowboy is offline
