transmission problems - Diesel Forum - TheDieselStop.com
Old 12-13-2007, 09:53 PM   #1 (permalink)
I just lost reverse, and shifting into 3rd and 4th 4r100 trans.
any thoughts on what it could be ? rebuild time ?
dathomson is offline
Old 12-13-2007, 10:08 PM   #2 (permalink)
Re: transmission problems
BTS or John Wood if you have the big bucks, otherwise there are cheap ones for sale on ebay.
2001 F350 XLT 4X4 crew cab, dual rear wheels, long bed, black, 7.3l turbo diesel, automatic transmission, 4.10, shift on the fly, running boards, sliding rear window, 38 gal fuel tank, 11,500 gvwr, 20,000 gcwr, 7500 gvw, completely stock, 114,00 miles when purchased, now has 149,000 miles, repairs so far: starter, batteries, cps, brakes, tires.
DonWarkentin is offline
Old 12-14-2007, 08:33 AM   #3 (permalink)
Mark Kovalsky's Avatar
For some reason the direct clutch isn't applying. It is possible that there is a stuck valve in the valve body, or a bad seal in the clutch, or the clutch is destroyed, or....
Mark
Mark Kovalsky is offline
Old 12-14-2007, 12:06 PM   #4 (permalink)
Meatco1's Avatar
If you call John Wood, you can have your trans built & installed in 1 day. He also does a trans with a teriffic warranty at a cost of only $ 2900. Same trans as his higher cost one, but built with different converter.
Good for up to 375 hp, which was good enough for me!
Richard
2001 C/C, 4x4, S/B, 3:73 L/S
John Wood Transmission
Tru-Cool Transmission oil cooler
DP Tuner with No Start, 20/40/60 Tow
80 Econ., 120 Race
AutoMeter 3 Guage, Pillar mount
6637 w Pete's Cover
Euro Chrome Clear Headlights
Euro Clear Signal Corner Lights
Bright Box Upgraded Headlight Harness
Defiant Light Bar w 2 KC Pencil Beams & 2 KC Driving Lights
Fumoto Drain Valve
Coolant Filtration System
Meatco1 is offline
Old 12-14-2007, 09:30 PM   #5 (permalink)
thanks, I will call him
Old 12-14-2007, 10:11 PM   #6 (permalink)
I got 166K miles out of a $2K Ford rebuilt tranny. The F250 saw weekly loads of 12-18K lbs last year. Pretty sure I got my moneys worth! Towing in OD only for those miles OD is now half out but I've sneaked another 2K miles out of it but due to high fuel costs and higher than normal RPM's ready for another Ford rebuilt unit.
99(4/99)F350 PSD 4X4 crew cab long bed dually lariat isspro triple pod air bags with compressor
99(6/99)F250 PSD 4X4 X-cab short bed xlt 5in str8 piped air bags autometer ultra light triple pod bought 8/15/01 w/40k miles first diesel
00(12/99)Excursion PSD 4X4 limited triple pod
00 BMW 328CI 2dr silver fully loaded
65 Mustang 289 V8 4brl
69 GTO 400 4spd
04 and 09 PJ 15k dump trailer 04 H&H 9K tilt bed 98 Haulmark 7x14 enclosed
86GLHS is offline
Old 12-14-2007, 10:36 PM   #7 (permalink)
Jinco's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 86GLHS</div><div class="ubbcode-body">I got 166K miles out of a $2K Ford rebuilt tranny. The F250 saw weekly loads of 12-18K lbs last year. Pretty sure I got my moneys worth! Towing in OD only for those miles OD is now half out but I've sneaked another 2K miles out of it but due to high fuel costs and higher than normal RPM's ready for another Ford rebuilt unit. </div></div>
I am glad to hear this on the Ford rebuild. I had one installed last January only it cost me $4000. I think I got ripped on the price but it has done fine so far and has a 3 year 75,000 mile warranty.
Buy Ford. They're not taking bail-out money.
2000 F250 XLT PSD Crewcab, Longbed, 4x4, Auto, LS 3.73
Ford AIS, Frantz Bypass Oil Filter, Baldwin Bypass Coolant Filter, Fumoto Drain Valve, 203* Thermostat, Stancor
Bilstein Shocks all the way around, Timbren SES (Rear), Bridgestone Dueler Revo A/T 265/75/16
Commander Monitor (gauges), Crimestopper CS-2016 DP II FM Remote Start/Alarm/Paging/Turbo Timer/Keyless
Rotella 5W40 Oil
, Texaco ELC Coolant, Mobile 1 ATF Trans and PS
My mods, repairs, and other truck Stuff
Jinco is offline
Old 12-15-2007, 12:20 AM   #8 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: jinco</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 86GLHS</div><div class="ubbcode-body">I got 166K miles out of a $2K Ford rebuilt tranny. The F250 saw weekly loads of 12-18K lbs last year. Pretty sure I got my moneys worth! Towing in OD only for those miles OD is now half out but I've sneaked another 2K miles out of it but due to high fuel costs and higher than normal RPM's ready for another Ford rebuilt unit. </div></div>
I am glad to hear this on the Ford rebuild. I had one installed last January only it cost me $4000. I think I got ripped on the price but it has done fine so far and has a 3 year 75,000 mile warranty. </div></div>
The guy at the parts desk said the Ford remans usually get more miles than the originals. He said most rebuilds in severe duty applications go for 160K miles or more. They sell a bunch to the delivery companies and have great luck with the rebuilds. $4K seems high with labor, I was quoted $3,400 were I bought the tranny. As a roofer I found a mechanic who needed a roof when my tranny was in need of replacement. The second install will be done by my regular mechanic for around $500 in his two stall shop. He put a motor in my wifes old Bronco 5.8 for around $400 with a tune up. Guess it's nice to know people!
69 GTO 400 4spd
86GLHS is offline
Old 12-15-2007, 02:46 AM   #9 (permalink)
My Photos: (18)
If you ever have an issues with that one and Ford won't take care of you or want some mods added to it call Travis in my signature.
Tim
2001 F-250 Crew Cab, short bed, 4x4, 4R100 with VB tuned by Travis's Automatic Trans, Lariat, Snugtop shell, Line-X bedliner, 265/75/R16 GY Silent Armor. DIY open element air filter. DIY 4 inch exhaust, from stock DP back to 45 degree turn down. Quadzilla Recon XZT moniter- EGT, Trans temp, Boost. DP tuner Stock, 40T, 40T high altitude, 80E, Curt MFG Q5 20K slider hitch, P3 brake controller, ATS housing. Blue Bullet
Sold-- Bright RED 1996 F350 XLT, 4X4, CC, 4.10 gears ,E40D, SRW, Rebuilt E40D at 190K with a 3yr/36K mile warrenty, by Travis's Auto Tranny 719-574-8104. Big Red
Proud Member of the NRA, helping to protect our American Rights!
New Toy: Can-Am Outlander MAX XT 650 -- AWESOME
5th wheel 2000 Dutchman 24RL with 12' slide
TCH777 is offline
Old 12-15-2007, 10:27 AM   #10 (permalink)
JimTJr's Avatar
My Photos: (20)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 86GLHS</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: jinco</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 86GLHS</div><div class="ubbcode-body">I got 166K miles out of a $2K Ford rebuilt tranny. The F250 saw weekly loads of 12-18K lbs last year. Pretty sure I got my moneys worth! Towing in OD only for those miles OD is now half out but I've sneaked another 2K miles out of it but due to high fuel costs and higher than normal RPM's ready for another Ford rebuilt unit. </div></div>
The guy at the parts desk said the Ford remans usually get more miles than the originals. He said most rebuilds in severe duty applications go for 160K miles or more. They sell a bunch to the delivery companies and have great luck with the rebuilds. $4K seems high with labor, I was quoted $3,400 were I bought the tranny. As a roofer I found a mechanic who needed a roof when my tranny was in need of replacement. The second install will be done by my regular mechanic for around $500 in his two stall shop. He put a motor in my wifes old Bronco 5.8 for around $400 with a tune up. Guess it's nice to know people! </div></div>
Perfect place for a "Slap on the forehead, and "Ya coulda had a BTS" commercial!
Nearly the cost of one, for a lesser product!
I know your a ways from BTS, so shipping and install would add to it some, unless you could have done the wrenching,,,,
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB. My pics! '03 Dually pics!, New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
Old 12-15-2007, 10:32 AM   #11 (permalink)
[quote=JimTJr
I know your a ways from BTS, so shipping and install would add to it some, unless you could have done the wrenching,,,, [/quote]
Only four hours, taking your time, with no lift to R&R a transmission.
Andy
Early 99 5-98, F350 extended cab, DRW LB 245,000 miles and counting, Hood insulation delete (Soaked with fuel), Hutch mod, Harpoon mod. Otherwise, pure stock (for now)
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
arisley is offline
Old 12-15-2007, 10:58 AM   #12 (permalink)
JimTJr's Avatar
My Photos: (20)
Well, I don't know why your saying that for sure,, I was talking about GLSH, or TCH,, the two posters above me,,,
JimTJr is offline
Old 12-21-2007, 10:16 AM   #13 (permalink)
My Photos: (18)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: JimTJr</div><div class="ubbcode-body">Well, I don't know why your saying that for sure,, I was talking about GLSH, or TCH,, the two posters above me,,, </div></div>
Jim what's your point? GLHS said he was happy with the money he spent and was going to do it again. He paid about 1 cent per mile on that trans. I just let a fellow CO member know about an excellent trans shop in CO if he needed help or wanted to upgrade his trans.
TCH777 is offline
Old 12-22-2007, 11:43 PM   #14 (permalink)
Jinco's Avatar
Thanks for the heads up TCH777. I made note of Travis's Auto Tranny.
Rotella 5W40 Oil
Jinco is offline
Old 12-28-2007, 09:08 AM   #15 (permalink)
I have 5 BTS trannies. I think Brian's track record is quite proven. It has been a well know fact for years now. Any vehicle that needs a trannie and does not get a BTS.. well the owner is just kidding him or herself. When one of there goes in you can just forget about it because it does what it is supposed to loaded or unloaded.
95 F250, Extended cab XLT, 3.55, BTS Transmission, Hypermax 4' exh. Royal Purple Bumper to Bumper
97 F350 Crew Cab, Dually, XLT 3.55, BTS Engine, BTS Transmission, BTS chip, H2 Hypermax Turbo, Hypermax 4" exh. Royal Purple Bumper to Bumper
97 F350 Extended Cab, Dually, XLT, 3.55, BTS Transmission, BTS chip, Banks 4" exh. Royal Purple Bumper to Bumper
02 F450 Crew Cab, Dually, Lariat 4.30,BTS Engine, BTS Transmission, BTS chip, H2 Hypermax Turbo, Hypermax 5" exh. Royal Purple Bumper to Bumper (what a truck!)
02 F450 Crew Cab, Dually, XLT Banks exhaust, BTS Engine, BTS Transmission, BTS chip, H2 Hypermax Turbo, Royal Purple bumper to bumper
02 F450 Crew Cab, Dually, Lariat, Magnaflow exhaust, BTS Engine, BTS transmission, BTS chip, H2 Hypermax Turbo, Royal Purple bumper to bumper
04 F350 Extended Cab, XLT, 3.73, 4WD, BTS Chip (what a difference). Royal Purple bumper to bumper
Advanced_Lube is offline
