Transmission won't go into park - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > '99 & up 7.3L Power Stroke Engine and Drivetrain
'99 & up 7.3L Power Stroke Engine and Drivetrain Discussion of the 99 & up 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 08-16-2007, 05:34 PM   #1 (permalink)
I pulled my 2001 F350 4X4 with 7.3l diesel and 4 speed auto transmission into a parking lot. I was pulling a 10,000 lb trailer. It was a slight uphill slope. I stopped, set the parking brake, put the transmission into park, and turned off the engine. When I took my foot off the service brake, the trailer and truck started rolling backward. I had not set the parking brake hard enough. Then something snapped in the transmission or transmission linkage. I looked on the floor of the truck beneath my feet, and saw a torx bolt lying there on the floor. Maybe it fell from the transmission linkage? Now the transmission will not go into park. I can still start the truck by putting the shifter lever into neutral. If I put the shift lever as far as possible toward park, the transmission is in reverse, but I can get the key in and out.
Do you think that something came loose in the linkage, or is the transmission broken?
2001 F350 XLT 4X4 crew cab, dual rear wheels, long bed, black, 7.3l turbo diesel, automatic transmission, 4.10, shift on the fly, running boards, sliding rear window, 38 gal fuel tank, 11,500 gvwr, 20,000 gcwr, 7500 gvw, completely stock, 114,000 miles when purchased, now has 170,000 miles, repairs so far: starter, batteries, cps, brakes, tires.
DonWarkentin is offline   Reply With Quote Quick reply to this message
Old 08-16-2007, 05:42 PM   #2 (permalink)
Re: Transmission won't go into park
Common problem, look up at the column, where the shifter lever connects, wiggle the shifter you will see the other loose bolt. Put a dab of blue loctite on it and bolt it back up, do the same to the other bolt. A flashlight mounted on you forehead is a great plus for this job.
Andy
Early 99 5-98, F350 extended cab, DRW LB 245,000 miles and counting, Hood insulation delete (Soaked with fuel), Hutch mod, Harpoon mod. Otherwise, pure stock (for now)
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
arisley is offline   Reply With Quote Quick reply to this message
Old 11-05-2007, 10:37 PM   #3 (permalink)
Thank you Andy, that fixed the problem.
Wheel & Tire Center
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
