Trouble Code P0603? - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 07-21-2011, 05:23 PM Thread Starter
Trouble Code P0603?
What do heck does Trouble Code P0603 (Internal Circuit Mod. KAM error) mean?
Thanks,
Griz
02 F250, 4X4, 4R100, 3.73, B&M Transmission Pan, Edge CTS Digital Gage, Tymar 4" Exhaust, Tymar Intake & HPX & TS 6 Position Chip. IH Bellowed Up-Pipes, RiffRaff AIH delete plug, Riffraff FRx Kit. 6.0 Transmission Cooler. Dieselsite Coolant filter & Transmission filter & 203 Thermostat & WW2 & TurboMaster & inter-cooler boots. BD CCV filter. Driven Diesel Fuel Tank Mod & Pre-Pump Filter. John Wood's valve body.
Griz is offline
post #2 of 8 (permalink) Old 07-21-2011, 05:48 PM
RDG
My Photos: (16)
Did you play with your tuner? Just means that the battery was disconected or you changed tunes on your Super Chip 1705.
TheDieselStop.com Moderator
TDS Member since 12.18.99 # 4366
NRA Member
Retired UAW 383
RDG is offline
post #3 of 8 (permalink) Old 07-21-2011, 05:57 PM Thread Starter
Yes...I did both. So that code is thrown whenever you disconnect your battery or use a tuner?
Griz
Griz is offline
post #4 of 8 (permalink) Old 07-21-2011, 09:24 PM
RDG
My Photos: (16)
Griz
Yep!
NRA Member
Retired UAW 383
RDG is offline
post #5 of 8 (permalink) Old 07-21-2011, 10:52 PM
woodnthings8's Avatar
Griz
When you change tunes you will here the truck do some clicking. This is a "reset" that needs to be done to the PCM. No different than restarting a computer after new software is loaded.
P0603 is just telling you the KAM (keep alive memory) was reset.
When you do that, just clear codes and you will not see it until the next tune change.
Ken
2002 F-350 CCLB 4X4, HD4R100 , Riffraff FRx, Riffraff CAC Boots & PRI's, Bellowed Up-Pipes, 4" Diamond Eye exhaust, Powerslot rotors,
, DP Tuner-F6, Autoenginuity, EEC-V Breakout Box, KCM S.S. HPX Line, S&B Filters intake, Quad Autometer gauge pod, Inovations canopy, Banks Big Head wastegate actuator, 6.0L Trans Cooler,
Zoo-dad, Dieselsite Coolant Filter, Cobra 29LTD/NW CB, DVD and always looking to do more....
woodnthings8 is offline
post #6 of 8 (permalink) Old 07-22-2011, 11:10 AM Thread Starter
Got it...I can sleep better now!
Griz
Griz is offline
post #7 of 8 (permalink) Old 02-06-2012, 06:11 PM
Wow, thanks! I have the P1316 code, pulled the driver side valve cover off to check harness. Reassembled and still have P1316, but then the P0603 showed up as well. Tomorrow is the passenger side. Have sure hoping I find the issue there.
FLF250 is offline
post #8 of 8 (permalink) Old 06-17-2014, 07:12 AM
I had the same problem with my UVC Harness. Ford has the upgrade to put a small plastic piece under the plastic spring clip to give it more elasticity, it costs roughly $15. Both my harnesses were lose and I still have the rough idle plus the thrown code, even after erasing it. So make sure you check your connections are tight at the battery.
Tycose is offline
