7.3L Power Stroke Engine and DrivetrainDiscussion of the 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Hi guys, I started my truck this morning and pulled out of drive, made it 4 houses down road and motor lost power and started running very rough and check engine light came on. I pulled over and drained fuel filter hose, replaced fuel filter and let it sit for a while, and still idled very rough like it was running on 6 or 7 cylinders. I did get it home and let it sit for 4 hrs and restarted and it idled fine, then 5 min later hit the gas ped and check engine light came back on and was running rough again. could this be fuel pump, bad fuel or what else. Not sure if I should get it towed to shop.
Any help would be appreciated.
Thanks again,
Chip
2002 F-250SD Lariat 4x4 ext cab 57,000 mi
K-N intake. MBRP 4" ss turbo back exaust muffler delete + 5" MBRP tip. dp tuner 60 80 econ and 120. AIH del. IC foil delete. BTS valve body. ISSPRO pyro mounted on steering collum. Isspro tranny and boost from disel manor on piller. brv from diselsite. Banks big head, allong w/Ats housing and wicked wheel. front leveling kit. rear leaf on each side 285/75 trail cutter mud tires, 8" drop Reese hitch. Prodigy brake controler to whoa camper.
Thanks again,
Chip
My 2002 was doing the same thing it was the two little screen filters inside the fuel pickup in the tank.
2002 F250 Lariat 4X4 two tone blue and silver7.3 sd BTS Trans,4in lift,35in BFG'S 4IN exhaust,super chip 80hp,pillar pyro boost,duel rancho 9000 front shocks,lockers front and rear,aluminum diff covers,k&n filter,clear marker lights,custom grill,sport push bar,front hitch recevier for warn 9000lb winch,bed liner,GPS,100 watt running lights,AGR ROCK RAM STEERING, piaa 910 driving lights, Kodiak SideWinders steps,off road unlimited disc brake upgrade
Is it hard to drop tank? I've never done that before.
Thanks,
Chip
Thanks,
Chip
Don't drop the tank... it is easier to just disconnect the fuel inlet line from the frame mounted fuel pump and attach a hose from a different fuel source (jerry can) to verify (or eliminate) the fuel source as being your issue...
but I would have to agree that you've likely got a UVC connector coming apart. If time equals money, then a diagnosis would cost less than the time it would take to remove the fuel tank.
The odds are unless you buy your fuel from a crappy little podunk station regularly your screens are not clogged. I always buy my fuel from truck stops, (PLaces with a HIGH turnover in the supply) that way there is much less chance of any algae growing in it. Or getting extremely dirty fuel. I have had my tanks down at one time or another in each of the trucks I have owned. The tanks were clean as can be, absolutely NOTHING in there that could clog. (Now like I said, if your not careful where you buy at regularly, there is the distinct chance you could have that happen), I imagine it's the UVC also. (Did you get a CEL?) If so, and there are IDM codes, then check the harness.
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now a full time Technician in the MOANG 12/10/07 My pics! and my New'03 Dually pics!, Charcoal Grey, Black and Grey interior, Black leather seats, Van Turbo/ATS ported housing/WW, Quad "A" pillar pod with Carbon Fiber series AUTO METER Gauges, FUMOTO Valve. BTS BUBBA" /TS 4pos chip, 4" Turbo back straight pipe/stainless 5" tip 131st F/W St.Louis MoAirNatlGuard We're losing the F-15s. BUT BEING HANDED THE KEYS TO THE B-2 BOMBERS at WHITMAN AFB, Near Kansas City, MO.!! We are Lindburghs OWN! Suffering from *PMS,, "Powerstroke mod syndrome"
U guys talk of how much cheaper it is to buy International parts for these psd, my question is would an International shop work on them or should i go to a local mechannic. Theres one I know that used to work for Ford who has his own shop now. (supposed to be good)
thanks
thanks
To have your tank droped go to the guy with his own shop
Thanks guys, it was my uvc harness clip. He put a locking clasp on both sides and everything back to normal.
thanks again
