I have a 2002 f250 230,000 miles on it. I just replaced the icp sensor twice( first one was bad from the get go) and the pig tail. When I'm driving down the high way and I hit a big bump at like a bridge the truck will stutter and lose power. Also if I exit the highway and come to a stop light shortly after the bump it will have a rough idle and then go away. It was doing this before I replaced the icp and pig tail. I figured they were related, guess not. Please help
Mine would studder at high speeds on a rough road and also durning any bump on a left turn. I found the main connection under the valve cover and the #8 cyclinder connection under the valve cover loose. Pushed them in tight and haven't had that problem since.
02 F250 with 7.3L, 4" downpipe w/ 5" exhaust, SCT 6 position tuner, wicked wheel, Stage 2 Trans, 4.11 detriot front & rear, 8" lift, 38" nittos
How your oil level ? You might want to have your fuel pressure checked. You can also checked the engine harnesses for rubbing/bare wires near the valve covers. Are you getting a service engine light or anything like that etc..
99 F250 XLT,4x4,SC,SB,A/T,PMT1,White/Silver w/silver ARE LSII tonneau,MB Razor's,295-60-20 Nitto trail grapplers,Rhino Liner,Rancho9000's,Bushwacker Street Flares,DP Tuner,True-Cool Max,AFE modified-W.D.RamAir,5"Hypermax exhaust,Hypermax DP,Firestone Ride-Rites,2.5" front leveling leafs,AutoMeter-ProComps/triple pillar,heated TTT mirrors,DEI remote start,Amsoil enhanced.
-update- here's what I found so far, the fuel heater plug was not clipped in so after some work got it to clip. Now I have not test drove over the bumps that are causing the problem. Would the fuel heater cause this?
