IS this true ???? - Diesel Forum - TheDieselStop.com
Old 09-22-2007, 12:02 PM   #1 (permalink)
GTstangs's Avatar
IS this true ????
went to a qiuck lube last night and the guy there told me i need to change my front diff fluid because it was low when he told me he can drain with out pulling the cover? also he said it takes GL 75/90 ? that dont sound right i have readed that it takes 75/140 right? THIS QUICK LUBE HAS ME GOING CRAZY ALL NIGHT THINKING ABOUT.
Thanks Craig
1999 F350 4x4 auto,hypermax gauges,F5 DP-TUNER CHIP hi-idle 80e 100p 140ex, Tymar Intake, magnaflow 5" exhust,35x12.5x16.5 tires 4inch pro comp lift 160k miles
pic
http://good-times.webshots.com/photo...79880629svEEKd
GTstangs is offline
Old 09-22-2007, 12:22 PM   #2 (permalink)
Re: IS this true ????
Those guys just suck out the fluid through the fill plug.
Early 1999 F350 6SPD 4x4 LARIAT Tymar, DP-F5, ITP Reg Return, 4" Exhaust **SOLD**
2002 F350 REG CAB DRW
DIRTBIKEZ is offline
Old 09-22-2007, 12:29 PM   #3 (permalink)
NorCalDiesel's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: GTstangs</div><div class="ubbcode-body">also he said it takes GL 75/90 ? that dont sound right i have readed that it takes 75/140 right? THIS QUICK LUBE HAS ME GOING CRAZY ALL NIGHT THINKING ABOUT. </div></div>
They do just suck the fluid out, which is fine and works. You should have 75/90 up front and 75/140 in the rear.
2002 X PSD, Billy Boat 4", AirRaid, Gillett Diesel Service Turbo, High Output turbo exhaust housing, KCM HPX Crossover, ITP Overboost Annihilator, Gauges: Boost, EGT, Trans Temp, Fuel Pressure and Water Temp
DP-Tuner 6 pos No Start - 140 Aggressive
Thanks Jody and Diane
Super Heavy Duty / Triple Disc 4R100 built by Jim Galatioto at ATO Transmissions in Sacramento.
NorCalDiesel is offline
Old 09-22-2007, 01:50 PM   #4 (permalink)
GTstangs's Avatar
thanks guys think i am going to just pull the covers off and do it myself.
pic
GTstangs is offline
