Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > 7.3L Power Stroke Engine and Drivetrain
7.3L Power Stroke Engine and Drivetrain Discussion of the 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 06-30-2008, 11:45 AM   #1 (permalink)
turbo bolt Qs
i noticed that there were two bolts missing from the exhaust side where it bolts to the senter section,, there are two on the top and two on the bottem,,, im missing the two on the top,,, and no iv never removed them,,, but i am not the first owner,, does any body have or know where to get them other then ford,, my dealership in town has to be run by six monkeys and three footballs,,, they never get any thing i have ordered right, or on time,, any help will be alsome, thanks,,
2000 f250 2wd/swa excab/longbed
AFE stage 1 with steel pipe,
EDGE EVO2, will be sending it to DP for some tunes
EDGEjuice,
straightpipe,
AIH mod,
CCV mod,
zoodad,mod
runs 15.5 1/4 at 87.55 MHP
jf0331 is offline
Old 06-30-2008, 11:57 AM   #2 (permalink)
dieselmann's Store
Scroll down near the bottom of the page.
2000 F-250 Ex-Cab Shorty - 4x4 - 7.3l - Auto - CAT ELC - 203* - Dieselsite Coolant Filter - AIH Delete - ITP HPX - Bilsteins - Walker BTM - Ford Severe AIS - CCV Canister - SCMT 1700 - Harpooned Tank w/ ITP Pre-Pump Kit - 312k
My truck pics
Check out my 1964 Toyota FJ40 Build
tjsulli790 is offline
Old 06-30-2008, 12:10 PM   #3 (permalink)
well thanks but both sits that might have the right stuff arnt any help,,,
the ford parts one search only go's back to 2004,
and the the other one does not come up all the way,, only the lode page with no enter spot,,,
does any body else have any thing else to add,,,,,
EDGEjuice,
straightpipe,
AIH mod,
CCV mod,
zoodad,mod
jf0331 is offline
Old 06-30-2008, 12:33 PM   #4 (permalink)
NorCalDiesel's Avatar
If you're referring to the 10mm (IIRC) bolts that bolt the exhaust housing to the center section, I may be able to help. I have some I took out of my old stock turbo when I rebuilt it. The rebuild kit had new bolts. I will send yo a couple if you PM me with your address.
Pat
2002 X PSD, Billy Boat 4", AirRaid, Gillett Diesel Service Turbo, High Output turbo exhaust housing, KCM HPX Crossover, ITP Overboost Annihilator, Gauges: Boost, EGT, Trans Temp, Fuel Pressure and Water Temp
DP-Tuner 6 pos No Start - 140 Aggressive
Thanks Jody and Diane
NorCalDiesel is offline
Old 06-30-2008, 12:57 PM   #5 (permalink)
you are the man,, thanks,,, thats the kind of help people come on here for,,,
EDGEjuice,
straightpipe,
AIH mod,
CCV mod,
zoodad,mod
jf0331 is offline
Old 06-30-2008, 01:12 PM   #6 (permalink)
klhansen's Avatar
My Photos: (92)
Turbo housing bolts coming loose is a known problem with the 7.3.
There is a kit with new bolts with interference threads that aren't supposed to back out from vibration, etc.
Using old bolts may just get you the same problem down the road. Maybe the kit would be a better way to go.
KIT-Turbocharger housing bolts (about $15)
Ford 1C3Z-9G486-AA
Int'l 1833768C91
99.5 F250 PSD Supercab LB 4x4, 6spd, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, Jody's 80 HP Econo PCM (classic version), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check here
klhansen is offline
Old 06-30-2008, 01:57 PM   #7 (permalink)
Ford 1C3Z-9G486-AA
Int'l 1833768C91
I do agree, but with the problems he is having with service and parts guys???
Old 06-30-2008, 02:05 PM   #8 (permalink)
i know it sounds crazy but if it has to happen then ill drive a hour to the next town and try there,,,thanks for the part#s
EDGEjuice,
straightpipe,
AIH mod,
CCV mod,
zoodad,mod
jf0331 is offline
Old 06-30-2008, 02:07 PM   #9 (permalink)
Let me know how it goes.
Old 06-30-2008, 02:47 PM   #10 (permalink)
FWIW, I had one bolt fall out several years ago and another was loose.At that time the vehicle was still under the 3/36 warranty and they replaced the entire turbo. The fellow who found the missing bolt problem said that if I was going to replace the bolts to be sure and clean out the hole where the bolt is threaded. He said the if it has soot in it that the bolt may break or it may never come out again.
jgr
Y2K F350, Ecab, LWB, SRW, 4X2, ZF6, Full Gauges, Ebrake, Chipped 271rwhp/584tq, Coolantfilter, fumoto valve, oil by-pass filter, CCV mod with return to intake, dahl 100, straight piped, PML cover, 203 stat and billet, AIS, Zoodad
pristine is offline
Old 06-30-2008, 06:26 PM   #11 (permalink)
klhansen's Avatar
My Photos: (92)
I didn't pay attention to the monkeys and footballs thing. Seen a few monkeys behind the counter myself.
He could get them from Powerstrokeshop.com in the mail. Never hurts to support a sponsor of the site. Saves on diesel fuel too.
klhansen is offline
Old 07-09-2008, 08:33 AM   #12 (permalink)
well i got the bolts in the mail,,, thanks again,, ill put them in tonight,, and ill remember to remove the soot on the hole,,, good tip that would have sucked,,,,
EDGEjuice,
straightpipe,
AIH mod,
CCV mod,
zoodad,mod
jf0331 is offline
