It looks like the oil is building up on the hoses leading out of the turbo. Don't know the proper nomenclature for them because I'm young but I know that's a problem. I don't know if I need a new turbo a new housing or both.
If your pedestal has been gutted for EBPV delete I would get a non ebpv pedestal or a proper done mod. by welding up supply and drain ports inside bore for control cyl.. also if you are bypassing oil from ebpv control cyl. enough to be coming from the hole that the rod comes through, suspect a major leak as there is a drain right under that hole that should overcome any minor leak. worth a look in my opinion....
Related Threads
The Diesel Stop
2.6M posts
210.8K members
Since 1999
