I had similar issue a while back. Check all your intercooler boots. I would only get 12lbs boost and couldn't hill climb with my toyhauler over 45mph. Ended up being one of my boots from the intake spider to the plenum on the head. The boot deformed and slipped out of the clamp
Early'99 F350,CC,Lariat,white w/beige,AT,DRW,LB,4X4,05 front & badge conversion,headlight harness upgrade,05 KR running boards,custom two-tone leather w/captains,Kenwood dd deck,Boston sl speakers & G3 12"subs,3"lift,adj Rancho shocks,Jetzon 255-85-16,Titan class V 2-1/2" hitch,custom frame mount camper tie-downs,late 99 hub/brake conv. with ADB slotted rotors,Firestone no-drill air bags,updated airbox w/Airaid,zoodad mod, pcm flashed w60hp-tow by DP-Tuner,quad-pod pillar w/Autometer Z-series(boost,pyro,trans,eng temp),B&M deep trans pan,custom built trans with billet converter,203* t-stat,MBRP 4" XP,Turbomaster wastegate controller, BRV+,Banks 6.0 technicooler, more engine mods to come
