Turbo Pedestal EBPV leaking oil-----switch to non-EBPV pedestal??? - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 03-31-2013, 07:30 PM Thread Starter
gn-guy's Avatar
OK, cleaned the motor and looks like I tracked my oil leak to the Turbo pedestal where the EBPV rod comes out.
Thoughts on just replacing the factory pedestal with one of those that does not incorporate the EBPV. Are there any sensors that would be effected? I'm using the stock turbo. Motor is a 2001 7.3 with 204,xxx miles.
I'm in northern Illinois, so it does get cold, but this is my backup truck, so I'm not to concerned about the engine warm up issues with eliminating the EBPV. The other option is to buy and install EBPV piston rebuild kit. Sure would be easier to just swap out the pedestal.
Any one else switched over to the non-EBPV pedestal? Or am I better off doing the piston rebuild?
Thank you,
Joe
gn-guy is offline
post #2 of 2 (permalink) Old 04-01-2013, 12:35 PM
Thank you,
Joe
Joe, if you are not worried about warm up issues then to me switching to a non-EBPV pedestal is easier than the rebuild kit. You might also want to change out the outlet to the Non EBPV outlet flange and do away with the EBPV flapper. I haven't done this yet but will soon. The parts are in the mail.
Griz
02 F250, 4X4, 4R100, 3.73, B&M Transmission Pan, Edge CTS Digital Gage, Tymar 4" Exhaust, Tymar Intake & HPX & TS 6 Position Chip. IH Bellowed Up-Pipes, RiffRaff AIH delete plug, Riffraff FRx Kit. 6.0 Transmission Cooler. Dieselsite Coolant filter & Transmission filter & 203 Thermostat & WW2 & TurboMaster & inter-cooler boots. BD CCV filter. Driven Diesel Fuel Tank Mod & Pre-Pump Filter. John Wood's valve body.
Griz is offline
