Turn signal problem - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 12-09-2005, 10:57 PM Thread Starter
Turn signal problem
Hey guys, on the 2000 in my sig. I'm having an intermittant problem with the turn signals working perfect one minute and the next time I use them it might work and blink once or twice or not at all. It's got me frustrated. When it was blinking I checked the fuses under the hood and had power on both sides of the fuse and when it's not working there isn't any power to either side of the fuses (the 7.5 amp fuses for trailer turn/stop). I checked them because I have have had problems with those fuses blowing randomly (about twice a year for my trailer lights). When the turn signals are not working the hazards will work. Sorry for being so lengthy and hope this makes sense.
Thanks, Eric
2008 Chev 2500HD CC SB LTZ 4X4 Duramax/Allison, dual alternators, B&W Turnover ball w/ Companion, 8'2" Boss V-plow, Timbrens
SOLD----2002 F350 CC SB, 4x4, Lariat, leveling kit, 285 BFG's, AIS w/ fender sleeve, AIC, A-pillar Pyro, Boost, Trans, SCMT, 4" Magnaflow turbo-back, AIH delete, Weatherguard toolbox, 8'2" Boss V-plow, Hide-a-way strobes, B & W Turnover Ball and Fifth Wheel Companion, Fumoto, 203* Stat, Bilsteins, XM, C-Betrs, 136,000 miles,Hella 500's up front, Hella flush mount back-up lights, Speed Bleeders, Air Lift rear bags w/ inside controller
Pulling this:
2005 Alumascape 35 FLQ by Holiday Rambler w/ 5 slides
2007 F550 4x4 XLT, 11' contractor dump box, dual alternators, Tow Command, Upfitters, C-Betrs, #19000 GVW, Fumoto, 9'2" Boss V-Plow, 8' V-box salt/sander, LED flashers
prograde is offline
post #2 of 9 (permalink) Old 12-10-2005, 01:22 AM
klhansen's Avatar
My Photos: (180)
Re: Turn signal problem
Your multifunction (turn signal, headlight, etc.) switch may be bad. The fuses you're checking are downstream of the multifunction switch.
I think there was also an issue with the wiring harness connector coming loose from the switch, which might cause your problem also.
Hope that helps.
), AIS,
regulated return,
klhansen is offline
post #3 of 9 (permalink) Old 12-10-2005, 01:28 AM
I've been seeing a lot of the multifuntction switches going bad lately. I just did one on my Excursion but also a lot on the cabs in the company I own. They are all Crown vics. It's an easy repair, takes 5-10 minutes to swap out.
2000 Black Excursion,PFC 2 piece rotors,Tipton tuned,BDP stage 2 singles, BDP H2E, AFE stage 2, Spearco 7.3, ITP Reg. return fuel system, Evans, BTS, 186,000 miles....And still goin' strong! Thanks Beansdieselperformance.com and Puredieselpower.com for all your help
BBBxcursion is offline
post #4 of 9 (permalink) Old 12-10-2005, 09:16 AM Thread Starter
Thanks guys, so I should check the connection to the multi-function switch and if thats good then it's prob. the switch?
Eric
Pulling this:
prograde is offline
post #5 of 9 (permalink) Old 12-10-2005, 07:01 PM Thread Starter
bump
Pulling this:
prograde is offline
post #6 of 9 (permalink) Old 12-10-2005, 07:07 PM
klhansen's Avatar
My Photos: (180)
Eric
That'd be my guess. There's a troubleshooting guide for the switch, where you check continuity across the connector pins in various switch positions. If you need that let me know.
), AIS,
regulated return,
klhansen is offline
post #7 of 9 (permalink) Old 12-10-2005, 08:49 PM Thread Starter
Thanks klhansen. I'll probably pick-up a switch.
Pulling this:
prograde is offline
post #8 of 9 (permalink) Old 12-11-2005, 12:18 PM
I put a combo switch in mine as well for simular problems. I got codes as well from the GEM module.
2000 Ford F-350 4x4 PSD ZF6 Trans
Banks 4"exhaust, chip, wastegate
Chad73 is offline
post #9 of 9 (permalink) Old 12-12-2005, 02:09 AM
Same as Chad73 a month ago.
Scott
Early 99, 4WD
Skydiver is offline
