Unleaded Gasoline in the tank of a Diesel truck - Diesel Forum - TheDieselStop.com
Old 03-09-2005, 09:33 PM   #1 (permalink)
I've read a few post on this topic on this board. The usual recommendation is to drain the tank, replace the filters, run a tank of diesel with additive afterwards.
On other boards I am hearing old timmers tell people to just throw in a quart of heavy weight motor oil and drive on or maybe a can of additive instead of the oil.
I just read a post from someone who took that advice. He drove from Las Vegas to Phoenix on a tank of unleaded with an additive added. He then took the motorhome in to the mechanic and had an oil analysis and had his injectors tested. He says it runs and tests just like a brand new diesel engine.
Does the engine oil lower the flash point of the gasoline?
Any truth to any of this? I trust you guys a lot more than I trust those old timmers.
Nate
2006 F350 PSD Crew Cab, Short Box -
MODS:
I wired my radar detector into the #4 upfitter switch.
Valley Slider, full articulatioon 5er hitch.
Layton Rampage 289 - two ATVs - Box of firewood - full tank of gas...what else ya need?
stuckinthemud is offline
Old 03-09-2005, 09:39 PM   #2 (permalink)
Re: Unleaded Gasoline in the tank of a Diesel truck
Uh, no. Drain and fill with diesel and lubricity additive.
Daniel H.
Ford certified diesel technician (I'm a glutton for punishment [img]/ubbthreads/images/graemlins/smile.gif[/img])
No diesel at the moment due to lack of funds (thanks Ford/SLTS).
biginch is offline
Old 03-09-2005, 09:50 PM   #3 (permalink)
My Photos: (11)
Thank goodness it was unleaded...Leaded gas might have done some real damage ;-)
2002 F-250 7.3L S/Cab 4x4. About 150 HP of minor mods.
Yanmar YM2500 diesel tractor. 3 cylinders, 80 inches and 30 throbbing horsepower.
Parrothead is offline
Old 03-09-2005, 09:54 PM   #4 (permalink)
fordmastertech's Avatar
[/ QUOTE ] On a older pump type injection engine you might get away doing this but don't count on it.
On a HUEI injector engine no way.
[img]/ubbthreads/images/graemlins/shrug.gif[/img]
Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
Old 03-09-2005, 11:28 PM   #5 (permalink)
I won't [img]/ubbthreads/images/graemlins/eek.gif[/img] be the one to gamble on this. Even at the current prices of diesel around here ($2.55GL). Still cheaper than a $5000 rebuild.
2001 F250 Lariat SuperCab 4X4 Automatic. Manual Hubs. ISS-Pro Guages & TTM. 4" Dynomax, Rancho 9000's, Jordan 2020 Brake Controller, AFE PG-7, ZooDad Mod, SCMT, PowerSlot Rotors, GoRhino Wheel to Wheel Bars, BridgestoneA/T Revos.
Diesel_Junkie is offline
