Vibration was a bad U joint - Diesel Forum - TheDieselStop.com
Old 12-20-2012, 12:02 PM   #1 (permalink)
I posted the fix for a bad vibration in another thread, but it's buried and I wanted to post separately for anyone doing a search on U joints. I'd had a bad vibration between around 50-60 mph while under load. Took my foot off the accelerator and the vibration stopped immediately. Took the truck to the shop yesterday, had the rear-most U joint replaced and now the vibration is gone.
Scott
Early 99, 4WD
Skydiver is offline   Reply With Quote
Old 12-20-2012, 03:06 PM   #2 (permalink)
klhansen's Avatar
My Photos: (175)
Glad you got it figured out, Scott.
If I had been fighting it that long, I would have had both driveshafts out and checked long ago.
Saw in your post original post that the mechanic that drove it when you initially had the problem said he didn't think it would be u-joints, among other things. I guess he was wrong.
I had a similar vibration (really not that bad, but noticeable) a few years bach on the way back from the drag strip out at Butte. Dropped the rear DS and replaced all 3 joints that night, finding one of them with needle marks on the drive side of the cross. That fixed it up and I was back at the drag strip the next day.
Hard or no-start? Check Here
Old 12-20-2012, 04:04 PM   #3 (permalink)
Two problems/fixes, actually. The first problem (vibration) from a few months ago was fixed when I replaced a bad ESOF hub. Then the newer vibration (U joint) started a few weeks ago and got steadily worse and that's what was fixed yesterday. Yesterday they also put in a new output seal (I believe where the drive shaft goes into the transfer case) where I'd been having a little leak. Like lots of things around here, winter was upon it before I knew what happened.
Scott
Early 99, 4WD
Old 12-20-2012, 10:35 PM   #4 (permalink)
klhansen's Avatar
My Photos: (175)
So true.
Old 12-26-2012, 11:29 PM   #5 (permalink)
My Photos: (31)
I just put a one piece aluminum driveshaft on my early 99 CC SB from CCI in Michigan. Pretty nice piece that only weighs 25 pounds. No vibrations after the swap, but in truth rebuilding the stock one would have cured it as well.
Kevin- Still have not needed to use the Injector B.O.B. since I made it from the pdf. Close to 300,000 miles now.
Andy
Early 99 F250 CC PSD, 6-Spd, 4x4, DP Tuner 4 Pos Chip, 4 BD Cat Back, Cat Delete, 3.5 Down Pipe, CCV Mod - Subman Style, ITP Fuel Sys, Dahl Fuel Filter, Home-made Headache Rack, Coolant Filter
64 Falcon Convertible
289 4-Speed 9"
Fat Diesel is offline   Reply With Quote
Old 12-27-2012, 09:39 AM   #6 (permalink)
Mongus's Avatar
Well, maybe you guys can help me out.
I just replaced all 3 u joints in my F550 ( spicer made in the USA - grease able ) and the carrier bearing ( Ford OEM )
I have a vibration at 60 mph up that is BAD !
Makes me drive at only 55 -60 mph.....
All new Bridgestone tires ( balanced and centrifical balancers too )
What can it be ??????????????
Thanks !
Note, I only did the replacement because I had the drive shafts powder coated.
I had a vibration before, but that was ( at least I thought ) bad ball joints.
Mongus rigs;
1992 F-Superduty Dump truck 7.3 - Luk SMF 5spd 5:13 rears-Ricksons 19.5 wheels & tires-Banks get kits.
This is my work hoarse !
2000 F550 - Crew cab -Custom Hood
Harley Flamed Fenders & Doors.
4x4-7.3 - South Bend 6spd 4:88 rears. Loaded ! Volant intake
Hog Performance 4" SS exhaust
Banks wheel, turbine, exhaust brake-Ceramic coated
AFE Blade Runner Spyder
Strickley Diesel Return Fuel & Banjo Bolts
IH up pipes - ceramic coated
Powder coated everything.
Brake Performance-slotted & dimpled rotors with performance pads
DP Tuner 80 Tow
Coolant filter system
Evens Coolant
203 thermostat
Bullet Liner coated Dana 60 front end
2008 F-350 Harley Davidson Crew cab - long bed - 6.4 - Banks-Six gun-Air intake-IQ-Dual Exhaust
2004 Pace American 28' x 9' x 8' enclosed work trailer. 18k GVW. Tri axle - loaded
Custom Built Roll -Off dump trailer. 17yard box. Double dual axles. 20k GVW.
Fully decked 2003 Anni Fat Boy.
Rare "Reaper Tins"
Mongus is offline   Reply With Quote
Old 12-27-2012, 11:10 AM   #7 (permalink)
My Photos: (31)
Double check to make sure the u-joint is seated correctly in the rear end pinion, and not slightly off.
289 4-Speed 9"
Old 12-27-2012, 03:03 PM   #8 (permalink)
klhansen's Avatar
My Photos: (175)
Did you have the balance checked on the driveshafts? That can cause problems even with new u-joints.
Old 12-27-2012, 03:37 PM   #9 (permalink)
Thanks !
I used to have a vibration around 60 and it got worse as I went faster. I had a bad pinion bearing and new tires fixed my issue. Its been some time, but I believe it was actually the tires that really fixed the issue.
Hope you get it figured out.
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)
PHP/Beans tuned/250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system with RR & FB delete, Pius LASB from Irate, Swamps HVHF IDM.
Autometer Nexus Guages, 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line. Baldwin PA2818(6637) RR Boots/CBillet Plenums, ('06) 26 row Tranny & PS Cooler, LarryB's Genuine Denso Starter
INFRNL is offline   Reply With Quote
Old 12-27-2012, 05:46 PM   #10 (permalink)
Mongus's Avatar
I did not have the drive shaft balance checked.
Would it go out of balance ?
My tires are a brand new Bridgestones. When I say new, I put the truck back together all at one time.
I had it in my shop for 6 months installing all the mods / new parts I bought. All $7,000 worth,,,,,,,,,,,,,,,,,,,,, love my truck
Mongus rigs;
DP Tuner 80 Tow
Evens Coolant
203 thermostat
Rare "Reaper Tins"
Old 12-27-2012, 07:50 PM   #11 (permalink)
klhansen's Avatar
My Photos: (175)
It might have if it got dinged by a rock or whatever sometime during it's life. Although if you weren't having problems before the u-joints were replaced, you could probably rule that out.
Hope you get it tracked down.
Old 12-28-2012, 07:12 AM   #12 (permalink)
Try to use frequency, speed, to include or elimiate certain groups of parts. Imbalance induces centrifugal force from the unequal distibution of mass / weight rotating around an axis. The defect amplitude produced is a mathmatically predictable curve that, all other things being the same, varies with the square of the speed / frequency increase or decrease. All that really means is the faster it goes more force amplitude the slower the less. That sounds like a so what answer but it gives imbalance characteristics that can be used diagnostically. First thing I would do is elimiate the most common imbalance source on the truck, the tires. Get them balanced on a Hunter balancing machine with the force balancing feature, the go from there. Drive shaft imbalance, that would show at engine rpm frequency not necessarily at vehicle speed or tire rotational frequency. Throttle on or throttle off make a differance in force, seem to be in the front or back?
2002 F250 7.3L PSD, bought new now at 202K miles, 4R100 Auto, Crew Cab, Short Bed, ITP Regulated Fuel Return system, ITP head to head SS oil cross over, Hutch in tank mod
Harpoon de tank vent, DIESELSITE Dahl 100 Pre-Pump Fuel Filter, DIESELSITE Return Fuel Line Cooler, DIESELSITE Engine Coolant Filter, DIESELSITE Auxilliary Transmission Cooler, DIESELSITE Gage Package, Pyro, Trans & Boost, Extreme Diesel AD injectors, Ford AIS Air Filter System, BTM straight through muffler, Moog Ball Joints, Rancho Shocks, Rotella ELC Coolant ,Stock Engine Program
Modified for I-Pod Connection
We b playing Scotland The Brave to Jimmy Hendrix
Last edited by Oneof6; 12-28-2012 at 07:14 AM. Reason: kaint spell big werds in de monin
Oneof6 is offline   Reply With Quote
Old 12-28-2012, 07:05 PM   #13 (permalink)
Mongus's Avatar
Thanks for the replies.
Ok, so I think it comes from the rear. ( nothing at all in the steering wheel )
It starts every time at 60 - 62 mph...
And the faster you go, the worse it gets. ( I back off after about 20 - 30 seconds. I don't want to hurt the truck )
I was on the road today for work, 1 hr on highway and 1 hour back home.
I am going to check to make sure nuts and bolts are tight.
Next, I will remove my centrifugal wheel balancers to see if maybe ,,,,,,,,,
I would love to track it down and get rid of this.
Mongus rigs;
DP Tuner 80 Tow
Evens Coolant
203 thermostat
Rare "Reaper Tins"
Old 02-14-2013, 10:07 PM   #14 (permalink)
The very same same thing happened to me with my 01 F250. New U joint in back and now smooth riding.
Buckbuster is offline   Reply With Quote
Old 02-15-2013, 12:38 PM   #15 (permalink)
01f25073's Avatar
Speaking from experience: I had a "hopping" vibration under braking from speed. Yet another problem hard for Ford mechanics to diagnose, but I would suppose this isn't that common as higher constant speed vibrations are. When the right driveline tech drove while I rode with him, he said all we can do is replace the driveline. He suggested to take it to a highly regarded driveline shop for repair (which was the best advice he could have given me). So........
If you are having driveline issues OR you replace your driveline, take your ride to a reputable driveline shop for service. If they are good, they will get rid of the non-greaseable u-joints for greaseable ones and balance the shaft. I was told on when I picked up my truck that if I grease the u-joints at every oil change, the driveline will last as long as the truck. Greasing u-joints is SUPER easy, just buy a grease gun with a flexible applicator, and keep tubes of grease. Since this happened, I swapped out ALL u-joints on my truck to greaseable ones for piece of mind.
2001 F-250 4X4 CC SB 7.3 4R100 3.73, BFGoodrich All-Terrain TA/KO, Motorcraft filters, Mile Marker manual hub locks w/ESOF (No hub "floating"), AIH delete, Rust-Oleum bed coating, Silverstar Ultra headlamps w/ clear headlight assemblies, 5,000K LED interior lamps; Moog greaseable u-joints, ball-joints, front hub assemblies; retractable bed hitch, original black CPS (BEST "mod" I have), Energy Suspension bushings, Red Heavy Duty ELC, Edge Evolution 15001 (for gauges), Walker BTM, Donaldson AIS
01f25073 is offline   Reply With Quote
