I have a 99 7.3 extended cab long bed doesnt vibrate upon acceleration but when i let off the throttle around 40 mph it vibrates and gets worse goin slower feels like a tire rubbing but thats not the issue anyone have any ideas before i start pulling the driveshaft??
Dont pull the driveshaft and lets see if we can narrow it down to a little bit closer of what it may be and causing the problem. Vibration can come from a number of different things. Here are some questions I have first:
1) is this a 4x4
2) where do you feel the vibration? front, rear, left side, right side?
3) do you only hear the noise at around 40mph and does it go away or become louder the quicker you go.
4) Is the noise only there when it is coasting or does it come and go at different speeds also
__________________ 2001 Ford F-250 Diesel 4x4 XLT Super Duty 6" Lift with Bilstein shocks 38" Toyo Open Country M/T Rough Country Dual Steering Stabilizer 5000K 55W dual HID headlights 5000K 55W HID Foglights Bully Dog Transmission Temperature Gauge Prodigy P3 Brake Controller Warn Premium Hubs Timken Wheel Assembly 135,000 miles
ya its 4x4, vibrations feels like its coming from around middle to the rear ands its damn near a constant vibration when slowing down from about 40mph wether i push in the clutch or down shift its still there. It just started doing this today and it feels like its getting worse and its constant
Sounds like of the rear deferential is going to need work.
I know that for my van there was much of what you are talking about when I would go down a hill or slow down.
Just an idea.
2000 E350 7.3PSD, Hellwig Stablizer bar,140 Lightforce with covers, 55Watt High/Lows HID's (watch which company) , extras in the bumper. 4"Aero Turbin and 4" all the way back. 1705 program, Scangauge II,265/75/16E Toyo Open Country, My Photos http://photos.thedieselstop.com/showgall...&stype=&ppuser=
"FAILURE IS NOT AN OPTION"
It riles them to believe
that you perceive
the web they weave
And keep on thinking free
The exact same thing happened to my truck and it was the u-joints in the driveshaft. I took it to a driveline shop for new u-joints, bearing, and balancing. Make sure to use greaseable u-joints if this is the problem. Good luck
2001 F-250 4X4 CC SB 7.3 4R100 3.73, BFGoodrich All-Terrain TA/KO, Motorcraft filters, Mile Marker manual hub locks w/ESOF (No hub "floating"), AIH delete, Rust-Oleum bed coating, Silverstar Ultra headlamps w/ clear headlight assemblies, 5,000K LED interior lamps; Moog greaseable u-joints, ball-joints, front hub assemblies; retractable bed hitch, original black CPS (BEST "mod" I have), Energy Suspension bushings, Red Heavy Duty ELC, Edge Evolution 15001 (for gauges), Walker BTM, Donaldson AIS
Rear most U-joint near the rear of the truck. Pull the entire driveshaft, have all the u-joints and carrier bearing replaced and have the shop re-balance the entire driveshaft. Sometimes the saddle clamps will loosen up on the u-joints themselves. Check the bolts before you loose the driveshaft.
__________________ LED running lights below doors for turn signals, marker lights, and courtesy lights from JadSolution
FOKISD (Ford, Ohio, Kentucky, Indiana, Super Duty Club), Charter Member.
2001 F-350, PSD, 4X4, True Blue, 152 WB, SRW, Auto Trans, Manual Hubs, PMT3, Off Road Package, AIC, Heated Excursion Tow Mirrors w/cut off switch, Extang Tonneau Cover, Westin Step Bars, Lund Bug Shield, Nifty floor mats, Custom rear bumper/w fog reverse lights & 3rd brake light, LED running lights below doors, Poron USA reverse backup sensors.
"It's mine,ALLLLL mine, (Till Andrea wants to drive it)"
